[mapguide-users] Is everbody on holiday or something?
Willem Schwarte willem at giskit.nl
Tue Jul 25 09:14:34 EDT 2006
Does it need to be a specific version? Because I tried one that was
installed with PHP5, but that one gave errors. Another gave also errors.
Willem
Van: Traian Stanev [mailto:traian.stanev at autodesk.com]
Verzonden: Tuesday, July 25, 2006 3:09 PM
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] Is everbody on holiday or something?
You need to copy libmysql.dll to the directory where the provider dll
is, likely under /FDO/bin relative from where acad.exe is located.
Autodesk can't legally distribute MySQL binaries, hence you have to
download it yourself. This should be documented somewhere in the Map
documentation.
Traian
Sent: Tuesday, July 25, 2006 9:04 AM
Subject: [mapguide-users] Is everbody on holiday or something?
Where is the feedback? Is Autodesk still reading this list?
The MySQL provider does not give me geometry. I have exported the access
database to mysql.
Also could not test connection in Map 2007 because libmysql.dll was not
found?!
Willem
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060725/ffdfbc01/attachment.html
More information about the Mapguide-users mailing list
