[mapguide-users] Is everbody on holiday or something?
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue Jul 25 09:43:46 EDT 2006
You must select the geometry when creating/editing the datasource, not
on the layer.
Kenneth
Willem Schwarte skrev:
> Here is what I see in studio when connecting to mysql through
> Mapserver Enterprise 2007.
> There are X and Y columns, but why can't I choose a geometry? I just
> want to create a point layer from a database source, just like I did
> on windows with the odbc FDO.
> Willem
> *Van:* Willem Schwarte [mailto:willem at giskit.nl]
> *Verzonden:* Tuesday, July 25, 2006 3:26 PM
> *Aan:* users at mapguide.osgeo.org
> *Onderwerp:* RE: [mapguide-users] Is everbody on holiday or something?
> I tried the one that comes with mysql and now I can connect. But in
> the list of data stores there is nothing. I'm trying to create one no
> to check differences.
> Willem
> *Verzonden:* Tuesday, July 25, 2006 3:15 PM
> Does it need to be a specific version? Because I tried one that was
> installed with PHP5, but that one gave errors. Another gave also errors.
> Willem
> *Van:* Traian Stanev [mailto:traian.stanev at autodesk.com]
> *Verzonden:* Tuesday, July 25, 2006 3:09 PM
> You need to copy libmysql.dll to the directory where the provider dll
> is, likely under /FDO/bin relative from where acad.exe is
> located. Autodesk can't legally distribute MySQL binaries, hence you
> have to download it yourself. This should be documented somewhere in
> the Map documentation.
> Traian
> *From:* Willem Schwarte [mailto:willem at giskit.nl]
> *Sent:* Tuesday, July 25, 2006 9:04 AM
> *To:* users at mapguide.osgeo.org
> *Subject:* [mapguide-users] Is everbody on holiday or something?
> Where is the feedback? Is Autodesk still reading this list?
> The MySQL provider does not give me geometry. I have exported the
> access database to mysql.
> Also could not test connection in Map 2007 because libmysql.dll was
> not found?!
> Willem
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
