PhpApi problem
Marcus Spurkel
mspurkel at pacbell.net
Tue Jul 25 14:44:11 EDT 2006
I'm getting a "undefined symbol: empty_string in Unknown on line 0"
error when I try to load libphp_MapGuideApi.so into PHP. It's probably
because I'm trying to use PHP 5.1.4, which has some significant changes
to the Zend code (among other things). I tried replacing Oem/php with
the latest source version from php.net and then re-making PhpApi but
that generated a ton of errors. Is there an easy way to get it to run
with PHP 5.1.4, or will I need to back my version down to 5.0.5?
-Marcus
More information about the Mapguide-users
