[mapguide-users] Some Help with Raster!!!
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Tue Jul 25 15:13:25 EDT 2006
Did you install the Raster FDO
(https://mapguide.osgeo.org/files/documents/12/76/Raster.zip)?
Arq. Luis E. Marin M. wrote:
> I need put some raster behind of my actual map I successful created my
> layers but y cat load the rasters because a error that say " server
> does not support requested provider: autodesk.raster" and I cant load
> my rasters any can helpme please!!! I very cuffused!!!
> Many thanks and sorry about my english
> CEO
> Simbiosis Group Inc.
> +58-2129432453 CCS
> +58-4166050203 CCS
> +01-3109283934 USA
> *****REGULACIÓN DE USO DEL CORREO ELECTRÓNICO DE Simbiosis Group Inc.
> HACIA INTERNET*****
> La información contenida en este correo electrónico y cualquier anexo
> puede ser de carácter confidencial y es propiedad de Simbiosis Group
> Inc. Sólo está permitido su uso, copia, transmisión, recepción o
> distribución a personas debidamente autorizadas. Si usted recibió este
> correo por error por favor destrúyalo y/o elimine cualquier copia
> guardada en su sistema y notifique inmediatamente al remitente o a la
> dirección de correo electrónica info at simbiosisgroup.net
> <mailto:info at simbiosisgroup.net>. Usted no debe utilizar la
> información contenida para ningún propósito ni compartirla con otras
> personas.
> This e-mail, including any attached files, may contain confidential
> and privileged information for the sole use of the Simbiosis Group
> Inc. Any review, use, distribution, or disclosure by others is
> strictly prohibited. If you are not the intended recipient (or
> authorized to receive information for the intended recipient), please
> contact the sender by reply info at simbiosisgroup.net
> <mailto:info at simbiosisgroup.net> and delete all copies of this message.
*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-4GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users
