[mapguide-users] PhpApi problem
Marcus Spurkel mspurkel at pacbell.net
Tue Jul 25 18:09:40 EDT 2006
Too many to count.  Many of the "'zend_xxx' was not declared in this
scope" variety.  But I just realized something: all I did was swap out
Oem/php with 5.1.4, then "make clean" and "make" in Web/src/PhpApi.  I
probably have to go back farther than that, don't I?  Do I need to
re-make the entire project?
-Marcus
Traian Stanev wrote:
>I recently replaced Oem/php with 5.1.4 and it compiled fine for me. But
>I did that on Windows.
>What kinds of errors are you getting?
>Traian
>-----Original Message-----
>From: Marcus Spurkel [mailto:mspurkel at pacbell.net]
>Sent: Tuesday, July 25, 2006 2:44 PM
>To: users at mapguide.osgeo.org
>Subject: [mapguide-users] PhpApi problem
>I'm getting a "undefined symbol: empty_string in Unknown on line 0"
>error when I try to load libphp_MapGuideApi.so into PHP.  It's probably
>because I'm trying to use PHP 5.1.4, which has some significant changes
>to the Zend code (among other things).  I tried replacing Oem/php with
>the latest source version from php.net and then re-making PhpApi but
>that generated a ton of errors.  Is there an easy way to get it to run
>with PHP 5.1.4, or will I need to back my version down to 5.0.5?
>-Marcus
>To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
