[mapguide-users] FW:
Dave Wilson
dave.wilson at autodesk.com
Wed Jul 26 14:03:56 EDT 2006
In our setup it was in /etc and we are logged on as root. I don't think
anything else was required. I couldn't find anything in the LD_LIBRARY
path.
Dave
_____
Sent: Wednesday, July 26, 2006 11:13 AM
Subject: RE: [mapguide-users] FW:
Is there a specific location for this file? Or how can I tell the system
where the file is?
Willem
_____
Van: Dave Wilson [mailto:dave.wilson at autodesk.com]
Verzonden: woensdag 26 juli 2006 18:01
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] FW:
When installing the ODBC driver from the rpm we had the same dependency
issue, but we installed it anyway using a --nodeps parameter.
I just tried this again. I put a single entry into the ODBC.ini file
(using the template from the website and corrected the path to the .so
file) and it worked fine. I didn't need to put anything in the
ODBCinst.ini.
In this case we used the 3.5 driver.
I suspect that the invalid XML is happening because it can't find the
ODBC.ini file.
Dave
_____
Sent: Wednesday, July 26, 2006 6:13 AM
Subject: [mapguide-users] FW:
When installing myODBC on Red HAt 3 ES we get the error below. Does
anybody know what this is and how to resolve this?
We tried bypassing it, but then Studio gives an " invalid XML document
(0,0)" error when looking for ODBC connections..
Willem
_____
Van: Bas van den Dikkenberg
Verzonden: woensdag 26 juli 2006 14:06
Aan: Willem Schwarte
Onderwerp:
error: Failed dependencies:
libstdc++.so.6(GLIBCXX_3.4) is needed by
mysql-connector-odbc-3.51.12-1
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060726/5582dfe7/attachment.html
More information about the Mapguide-users
