[mapguide-users] Is everbody on holiday or something?
Willem Schwarte
willem at giskit.nl
Thu Jul 27 09:35:26 EDT 2006
Hi Traian,
You are correct, Dave Wilson had the same answer. I'm now trying to use
myODBC, but I'm having problems with that too. Please read my previous
post about this..
Thanks,
Willem
Van: Traian Stanev [mailto:traian.stanev at autodesk.com]
Verzonden: donderdag 27 juli 2006 15:17
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] Is everbody on holiday or something?
I am not sure about the answer to this so someone should correct me if
I'm wrong... I think only the ODBC provider will let you specify
separate columns for x and y and then will treat that as a point. All
other providers expect the data to have a bona fide geometry property.
The x and y columns in your case are just simple data attributes, and
not geometry.
Traian
Sent: Tuesday, July 25, 2006 9:36 AM
Subject: RE: [mapguide-users] Is everbody on holiday or something?
Importance: High
Here is what I see in studio when connecting to mysql through Mapserver
Enterprise 2007.
There are X and Y columns, but why can't I choose a geometry? I just
want to create a point layer from a database source, just like I did on
windows with the odbc FDO.
Willem
Van: Willem Schwarte [mailto:willem at giskit.nl]
Verzonden: Tuesday, July 25, 2006 3:26 PM
I tried the one that comes with mysql and now I can connect. But in the
list of data stores there is nothing. I'm trying to create one no to
check differences.
Willem
Verzonden: Tuesday, July 25, 2006 3:15 PM
Does it need to be a specific version? Because I tried one that was
installed with PHP5, but that one gave errors. Another gave also errors.
Willem
Verzonden: Tuesday, July 25, 2006 3:09 PM
You need to copy libmysql.dll to the directory where the provider dll
is, likely under /FDO/bin relative from where acad.exe is located.
Autodesk can't legally distribute MySQL binaries, hence you have to
download it yourself. This should be documented somewhere in the Map
documentation.
Traian
Sent: Tuesday, July 25, 2006 9:04 AM
Subject: [mapguide-users] Is everbody on holiday or something?
Where is the feedback? Is Autodesk still reading this list?
The MySQL provider does not give me geometry. I have exported the access
database to mysql.
Also could not test connection in Map 2007 because libmysql.dll was not
found?!
Willem
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060727/0345704f/attachment.html
More information about the Mapguide-users
