[mapguide-users] Printing to specific scale doesn't work - wrong
scale
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Jul 27 14:21:43 EDT 2006
I had it backwards....to print something out so that it's ACTUALLY at
1:10000, you have to fiddle with it until it's around 1:9375...then you
can use a 1:10000 scale to measure things correctly. Hope that
illustrates the problem........still no rasters being printed either!
Andrew
Andrew DeMerchant wrote:
> Nope....nothing quite so simple unfortunately......also of note, I
> just tried to print the same thing out at 1:10666 (which should equal
> 1:10000, if I did my math right), but that just plain doesn't work...I
> get a blank page. I'm guessing that you can't just type in the scale
> that you want, unless it's in the list (though the program lets you
> think that you can do it)
> Andrew
> Andy Morsell wrote:
>> You don't have any printer specific override settings that might be
>> affecting this do you? Such as a "scale page to fit" or similar option?
>> Andy
>> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
>> *Sent:* Thursday, July 27, 2006 10:46 AM
>> *To:* users at mapguide.osgeo.org
>> *Subject:* [mapguide-users] Printing to specific scale doesn't work -
>> wrong scale
>> If you select a printout to be at a specific scale, it's wrong (off
>> by about 5%).
>> If you are using a custom print layout with a scalebar, it's easier
>> to notice right away. Print something at 1:10000, for example. Then
>> grab an actual 1:10000 scale and you'll see that the scale bar on the
>> page is too small. From 0 to 600 metres, it should measure 60mm, but
>> is actually only 56mm. This translates to a 40metre error when
>> scaling things off of the printout. The scalebar does actually match
>> the scale of the drawing though, but it is not 1:10000, as it claims.
>> Has anyone run into this? I've just submitted it as a bug....maybe
>> there's a workaround though....
>> Andrew
>> *Andrew DeMerchant*
>> *Computer Technologist*
>> ph.1-877-4GEMTEC x.163
>> fax 506-453-9470
>> /GEMTEC Limited <http://www.gemtec.ca>
>> /191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users
