[mapguide-users] PHP script for getting data from selected item(s)
James Card
James.Card at calcad.com
Thu Jul 27 18:16:38 EDT 2006
On Fri, 30 Jun 2006 13:36:02 -0700, Andy Morsell <amorsell at spatialgis.com>
wrote:
> That's awesome. Thanks for supplying to the group. One thing to note,
> however, is the MgPropertyType for whatever the KeyName field
> corresponds to. In your case, it is a string, so you are using
> $featureReader->GetString($KeyName). It won't be a string in all cases,
> so you may want to add a function to determine that dynamically along
> the lines of what Kori had in his code yesterday: [SNIP]
I've added a function to determine the MgPropertyType and retrieve the
appropriate value. It has survived my limited testing so far, but has not
been thoroughly tested yet.
Also, some of the target pages we're calling (ColdFusion applications
built around MapGuide 6.5) are expecting values to be encapsulated in
single-quotes, I've added an option to leave them in. Because it INCLUDEs
the constants.php file I placed it in the mapviewerphp directory to make
it a standard part of our toolset.
What it doesn't yet have, that I'm sure we'll need eventually, is the
ability to call the target page as an HTTP POST request rather than a GET.
PHP has a PECL extension for HTTP functions available that might make this
easy; it is not installed by default (and installation is not as
straightforward as it could be), so I'd like to limit the code to those
PHP functions that are included in the standard install.
I don't understand HTTP well enough to have PHP send the proper sequence
of headers for a POST, so I'm hoping someone here can add the bit of
intelligence that's still lacking.
James Card
California CAD Solutions, Inc.
209 578-5580
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060727/86db7110/passData.obj
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060727/86db7110/passData.gif
More information about the Mapguide-users
