[mapguide-users] Petitions too slow?
Andy Morsell amorsell at spatialgis.com
Thu Jun 1 12:06:59 EDT 2006
Hi Jose,
I'm curious how you got the object Properties to appear programmatically
after selecting the object?  I have some similar functionality and when I
select the object programmatically (using MGSelection.AddFeatureID), it is
only highlighted on the map with the Properties pane empty.
Thank you.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
-----Original Message-----
From: Jose Manuel C G [mailto:gis at mapas-sll.com]
Sent: Thursday, June 01, 2006 7:57 AM
Subject: Re: [mapguide-users] Petitions too slow?
Here is the modified code in php, the basic is here, the rest you can
imagine...
<?php
    include 'appconstants.php';   //In this file I've included the code to
$siteConnection, $resourceService and $featureService.
	$matches = 0;
		$StrAddr = trim($_GET['StrAddr']);
		$NumVia = trim($_GET['HouseNumber']);
        if (strlen($owner) > 0){
			if (strlen($NumVia) > 0){
				$filter = "NOMBREVIA LIKE '" . $StrAddr . "'
AND PRIMERNUM = " . $NumVia . "";
				$featureResId = new
MgResourceIdentifier("Library://<path to your
FSource>/Callejero.FeatureSource");
				$queryOptions = new MgFeatureQueryOptions();
				$queryOptions->SetFilter($filter);
				$geometryReaderWriter = new
MgAgfReaderWriter();
				$featureReader =
$featureService->SelectFeatures($featureResId,
"Callejero", $queryOptions); // Callejero is the name of the layer
				while ($featureReader->ReadNext()){
					$name =
$featureReader->GetString('NOMBREVIA');
					$tipovia =
$featureReader->GetString('TIPOVIA');
					$refcat =
$featureReader->GetString('CRT');
					$byteReader =
$featureReader->GetGeometry('Geometry');
					$geometry =
$geometryReaderWriter->Read($byteReader);
					$point = $geometry->GetCentroid();
					$x =
$point->GetCoordinate()->GetX();
					$y =
$point->GetCoordinate()->GetY();
					echo "setArrayElement(' $tipovia
$name, $NumVia ');";
					$matches++;
			}else{
			//  If the user only input Street Name
				$featureResId = new
FSource>/Calles.FeatureSource");
				$featureReader =
"Calles", $queryOptions); //Calles is the name of another layer
					$idc =
$featureReader->GetString('IDC');
					$tipovia =
					$name =
					$escala =
$featureReader->GetString('ESC');
					$byteReader =
					$geometry =
					$x =
					$y =
$name ');";
					$matches++;
		$featureReader->Close();
        }else{
		// The user doesn't input a Street Name
		echo "traducir('Bsq03');"; // traducir is a function in
javascript to translate.
		if ($matches == 0){
		echo "traducir('Bsq04');";
View this message in context:
http://www.nabble.com/Petitions+too+slow--t1715911.html#a4663663
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
