[mapguide-users] Tooltip Issues in Internet Explorer
Butler, Juan P jpbutler at co.pinellas.fl.us
Fri Jun 2 14:10:59 EDT 2006
This goes back to a post that I had earlier.   You are referencing an
image on a server somewhere, correct?  I have this working great too,
but in IE the tool tip acts erratically.
I have images that I stream from the database or other locations.   I
wish I could take this a bit further and place the streamed data into
the tool tip.   Hopefully, in upcoming releases this will be supported
and the performance will be OK.
I have a Google map that works perfectly for streaming images in the
tool tip information for the markers.   It utilizes XSL to format tool
tip information.
- Juan
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Friday, June 02, 2006 11:56 AM
Subject: [mapguide-users] Tooltip Issues in Internet Explorer
I have custom tooltips built in a map and as part of that tooltip, an
external page is called that generates an image.  This works extremely
well in Firefox as well as the Studio preview window.  However, in
Internet Explorer I get very odd, inconsistent results.  These tooltips
sometimes work correctly, but most of the time, as you hover over a
parcel, it makes repeated calls to the server and never "holds still".
This looks an issue with AJAX handling between the two browsers.
Here is a link to try first in Firefox and then in IE:
http://mapguide.spatialgis.com/mapguide/mapviewerajax/?WEBLAYOUT=Library
%3a%2f%2fSpokaneMaps%2fWeb+Layouts%2ftest.WebLayout&USERNAME=Anonymous
<http://mapguide.spatialgis.com/mapguide/mapviewerajax/?WEBLAYOUT=Librar
y%3a%2f%2fSpokaneMaps%2fWeb+Layouts%2ftest.WebLayout&USERNAME=Anonymous>
Any help on this from Autodesk would be greatly appreciated.  Thank you.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com <http://www.SpatialGIS.com>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060602/9b8762a0/attachment.html
More information about the Mapguide-users mailing list
