[mapguide-users] Mapguide Server Service does not start
Bruce Dechant bruce.dechant at autodesk.com
Fri Jun 2 16:31:03 EDT 2006
I have updated artifact MG269.
Bruce
-----Original Message-----
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Friday, June 02, 2006 2:11 PM
Subject: RE: [mapguide-users] Mapguide Server Service does not start
Thanks Bruce.
Would you mind closing MG269 as well?  Same issue.
https://mapguide.osgeo.org/servlets/Scarab?id=MG269
Jason
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: Fri 2006-06-02 12:43 PM
I made a submission today MG307 that changed the MapGuide server service
name to "MapGuideServer" instead of "Server". Hopefully, this will help
alleviate the name issue in the future.
Bruce
Sent: Friday, June 02, 2006 10:51 AM
That's its display name, but its service name is "Server".  You can see
this by right-clicking on the service and going to Properties.
NET STOP/START gets confused and thinks you're referencing the lanman
service, but the service manager and the SC command (XP/w2k3 only) do OK
with it.
Jason
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Fri 2006-06-02 9:00 AM
On my installations the service is called "MapGuide Server".
Andy
From: Berdel, Brian [mailto:brian.berdel at mcmtrans.com]
Sent: Friday, June 02, 2006 7:02 AM
Not sure if this is relevant, but I am not sure if it was the best idea
to
name the service "Server".  There is already a service called that and
if
you try to start and stop at cmd prompt it thinks you are talking about
the
lanman service.
Went back to a restore point and now the service starts but immediately
stops.   Also tried uninstalling and re-installing all components.
Sent: Thursday, June 01, 2006 4:04 PM
Subject: [mapguide-users] Mapguide Server Service does not start
It was working fine, then all of the sudden... It will not start and I
get
an error in the event ID
Event Type:     Error
Event Source:   Service Control Manager
Event Category: None
Event ID:       7022
Date:           6/1/2006
Time:           2:06:01 PM
User:           N/A
Computer:       FW0249
Description:
The MapGuide Server service hung on starting.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
