[mapguide-users] MapGuide Open Source Web Studio
Paul Spencer
pspencer at dmsolutions.ca
Mon Jun 5 22:13:24 EDT 2006
ahhh ... thats the trick.
When I looked at an uploaded shape file using GetResourceContents
<?xml version="1.0" encoding="utf-8"?>
<FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
<Provider>OSGeo.SHP.3.0</Provider>
<Parameter>
<Name>DefaultFileLocation</Name>
<Value>%MG_DATA_FILE_PATH%</Value>
</Parameter>
</FeatureSource>
it didn't seem to list the actual files so I wasn't sure what I could
do with this and SetResourceContent. Using EnumerateResourceData
listed the actual files but there didn't seem to be a way to put this
XML back into the server. Now that I look at the schema for the
feature source, I realize that I could probably just have multiple
Parameter tags, one for each file, and used SetResourceContent :)
Cheers
Paul
On 5-Jun-06, at 9:48 PM, Robert Bray wrote:
> Paul,
> A typical FeatureSourceDefintion (for SDF) that is created by
> Studio looks like:
> <?xml version="1.0" encoding="utf-8" ?>
> instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> <Provider>OSGeo.SDF.3.0</Provider>
> <Parameter>
> <Name>File</Name>
> <Value>%MG_DATA_FILE_PATH%Parcels.sdf</Value>
> </Parameter>
> <Parameter>
> <Name>ReadOnly</Name>
> <Value>TRUE</Value>
> </Parameter>
> </FeatureSource>
> If you replace the %MG_DATA_FILE_PATH% with a physical path to the
> file on the servers file system you can effectively "reference"
> data and not worry about uploading it. A similar technique can be
> used for SHP files, Raster files, etc.
> Bob
> -----Original Message-----
> From: Paul Spencer (External)
> Sent: Mon 6/5/2006 9:14 PM
> To: users at mapguide.osgeo.org
> Cc:
> Subject: Re: [mapguide-users] MapGuide Open Source Web Studio
> The preview of the web layout is from the sample Sheboygan package.
> Web Studio can load web layouts using the ajax viewer, you just can't
> create or edit them yet.
> I had originally thought that we would only be supporting data that
> was already on the server. The data that is stored on the server is
> reported through the MapAgent using the EnumerateResourceData
> operation. The XML returned from this lists the data file or files
> that are part of the resource. There doesn't seem to be a way to
> create the XML and put it into the server. Thus it doesn't seem
> possible to support creating a feature source that refers to data
> already on the server. I could be wrong about this, though.
> Cheers
> Paul
> On 5-Jun-06, at 6:20 PM, Jason Birch wrote:
> > IANAP (I am not a Paul), but I think that "The primary goal of this
> > release is to enable users to get data into the server" must mean
> > that there is some mechanism for either uploading data, or (based
> > on some questions Paul asked on this list) possibly referring to
> > data that is already on the server.
> > One of the screen shots shows a web layout. Perhaps there is a
> > "default" web layout provided?
> > Jason
> > ________________________________
> > From: Andy Morsell [@spatialgis.com]
> > Sent: Mon 2006-06-05 2:44 PM
> > Subject: RE: [mapguide-users] MapGuide Open Source Web Studio
> > Wow, that really does look great. I'm confused on a couple of
> issues,
> > though. First, it doesn't support load procedures, etc. I think
> > that makes
> > sense for a pure web-based authoring tool, but at this point,
> > people will
> > still have to use MapGuide Studio to load their data and then
> > author it with
> > this tool instead? I could see that a company may choose to have a
> > couple
> > of licenses of Studio for this and other advanced functionality
> > purposes and
> > then use the open source version for other folks needing to create
> > maps from
> > that data. I also imagine that others will eventually develop open
> > source
> > tools for loading data without the need for Studio.
> > Second, you say that it doesn't support web layouts. Are the
> > webLayout's in
> > the Web Studio version different than MapGuide Studio web layouts?
> > Thanks again for developing this open source tool. It will be very
> > useful.
> > <winmail.dat>
> > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > For additional commands, e-mail: users-help at mapguide.osgeo.org
> |Paul Spencer pspencer at dmsolutions.ca |
> |Applications & Software Development |
> |DM Solutions Group Inc http://www.dmsolutions.ca/|
More information about the Mapguide-users
