select objects on multiple layers
Willem Schwarte
willem at giskit.nl
Tue Jun 6 09:53:11 EDT 2006
Hi ,
I now use this code to generate a link with xml to select objects found
on the layers in a map:
$filter = "CRE03 = '00000030UP-BBW' AND
(HYPERLINK = 's199' OR HYPERLINK = 's132')";
$opts = new MgFeatureQueryOptions();
$opts->SetFilter($filter);
$layers = $map->GetLayers();
for ($i = 0; $i < $layers->GetCount(); $i++)
$firstLoop = 1;
$layer = $layers->GetItem($i);
if ($layer)
$featureClassName =
$layer->GetFeatureClassName();
$srcId = new
MgResourceIdentifier($layer->GetFeatureSourceId());
$features =
$featureService->SelectFeatures($srcId, $featureClassName, $opts);
$hasResult =
$features->ReadNext();
if($hasResult)
$sel = new
MgSelection($map);
do
$sel->AddFeatureIdInt32($layer, $featureClassName,
$features->GetInt32('FeatId'));
while($features->ReadNext());
$selText = StrEscape($sel->ToXml(), true);
<a href="#" onClick="CellClicked('<?=$selText;?>');">Click to select
objects</a>
}else
echo "no results";
} // endif
} // next $i
Now I will e.g. get 2 links. What I really want to achieve is that 1 XML
string is created so if I click on the link, all objects on all layers
will be selected.
Is this at all possible?
Willem
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060606/60a72c19/attachment.html
More information about the Mapguide-users
