[mapguide-users] SetOrderingFilter method on SDF datasource...
Dave Wilson dave.wilson at autodesk.com
Mon Jun 12 11:10:45 EDT 2006
In case you were wondering what options you can exercise against a
particular feature source you can try the following:
>From http://localhost/mapguide/mapagent/index.html (if you are using
Apache add your port)
Select FeatureServices
Execute GetFeatureProviders
Take the string value from the Name tag and use it to execute
GetCapabilities
The resulting list will tell you what operations, functions etc are
supported by the provider.
The simple answer is no ordering is not supported by SDF.
Regards,
Dave
  _____
From: Warren Medernach [mailto:warren.medernach at imaginit.ca]
Sent: Monday, June 12, 2006 8:55 AM
Subject: [mapguide-users] SetOrderingFilter method on SDF datasource...
Hello all,
I am successfully filtering my feature source, and now I am attempting
to set an order filter but I'm getting the following error msg:
ROOM_NO LIKE 'A2-31%'Feature Service exception - Ordering Option is not
supported by providerFeature Service exception - Ordering Option is not
supported by provider Exception occurred in method
MgServerSelectFeatures.ApplyOrderingOptions at line 410 in file
c:\build_tux_area\mgdev\server\src\services\feature\ServerSelectFeatures
.cpp
Can I not call the SetOrderingFilter method on an SDF datasource?
Any help and/or guidance would be greatly appreciated.
Thanks
   Warren Medernach
   IMAGINiT Professional Services
   wmedernach at rand.com <mailto:wmedernach at rand.com>
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060612/cfe4490d/attachment.html
More information about the Mapguide-users mailing list
