[mapguide-users] Mapguide dotnetsampleviewer problem
kenny at keniginc.com
Fri Jun 23 15:54:31 EDT 2006
Dennis,
I had similar problem when I setup my MG OS last week.
The only way I was able to solve that problem is by taking following steps:
1. Open the Windows "Control Panel"
2. Select the "Administrative Tools" entry
3. Launch the "Services" panel
4. Status for ?MapGuide Server? should be ?Started?. If not, right
click on the "MapGuide Server" item and select "Start"
I researched the forum to find this solution.
Hopefully, it works for you too.
Quoting Dennis Megarry <dennis at myairplane.com>:
> I've setup Mapguide on a Windows 2003 box, installed the sample data and
> setup everything correctly (as far as I know), when I try to run the sample
> ajax viewer, I get:
> "Cannot establish connection.Cannot establish connection. Exception occurred
> in method MgServerConnection.Open at line 94 in file
> c:\build_tux_area\mgdev\common\service\services\ServerConnection.cpp :
> I stopped the mapguide service and started it in interactive mode, but
> nothing appears in the dos window.. Anyone run into this before?
> Dennis
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
