[mapguide-users] OGR Provider in FC4
Traian Stanev
traian.stanev at autodesk.com
Tue Jun 27 08:44:37 EDT 2006
It could be several things causing this. I assume you compiled and
installed the provider successfully (by adding an entry to
providers.xml), since you get a Data Connection page for it in Studio.
One thing I would check is whether the libOGRProvider.so has missing
dependencies (by running ldd -r on it). Also check the MapGuide server
error log for any Fdo exceptions -- there should be a message if it
can't even create a connection to OGR. If you run the server from a
command line (using /interactive), you will also be able to see the
exceptions printed on the console (the OGR provider may also print some
debug information to the console that you won't see in the logs). Also
make sure the FDO version listed in providers.xml entry for OGR matches
the versions listed for the other providers (there are some overzealous
version checks in the 1.0 code).
Traian
_____
Sent: Tuesday, June 27, 2006 12:03 AM
Subject: [mapguide-users] OGR Provider in FC4
I just got MGOS up and running today on Fedora Core 4. I am trying to
use the OGR provider to access data in PostgreSQL. When I try to create
a new data connection in Studio, the connection properties section is
blank. No "DataSource" or "ReadOnly" properties showing. Any help would
be appreciated.
Thanks,
Eliot Cline
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060627/ad2c4fd5/attachment.html
More information about the Mapguide-users
