Apache as CGI cannot customize authentication
newjim
j_oleary_ed at yahoo.ca
Wed Jun 28 14:52:16 EDT 2006
PHP in Apache2 in MapGuide is loaded as a CGI executable, as this line in
httpd.conf shows:
Action application/x-httpd-php "/php/php-cgi.exe"
However, you cannot customize your authentication unless PHP runs as a
module, that is, by commenting out this line and replacing it with:
LoadModule php5_module c:/php/php5apache2.dll
When you do that and restart Apache, you can trap the user login and
password. For example:
<?php
if ($_SERVER[PHP_AUTH_USER])
print "<script language='javascript'>alert('Hello
$_SERVER[PHP_AUTH_USER]')</script>";
//unset($_SERVER[PHP_AUTH_USER]);
elseif($_REQUEST['auth'])
Header("WWW-Authenticate: Basic realm=\"MapGuide Test Site\"");
Header("HTTP/1.0 401 Unauthorized");
<form>
<input type="submit" name="auth" value= "Authenticate" />
</form>
However, when you do that you lose the MG functions, which I presume are in
php_MapGuideApi.dll, such as MgInitializeWebTier
Is there a way that you can make the MG functions available to PHP when you
load it as a module?
View this message in context: http://www.nabble.com/Apache-as-CGI-cannot-customize-authentication-tf1863388.html#a5090509
Sent from the OSGeo MapGuide forum at Nabble.com.
More information about the Mapguide-users
