[mapguide-users] Create Package
    Andrew DeMerchant
    andrew.demerchant at gemtec.ca
    Wed Jun 28 16:05:22 EDT 2006
Click "About" on the top left....you must not have the right version.
Mine's got "Manage Packages". My versions are:
MapGuide Server (Version 1.0.0.16802)
MapGuide Site Administrator (Version 1.0.0.16802)
Andrew
Berdel, Brian wrote:
> I just downloaded the latest version of mgserver.exe and installed.
> Here is a screen grab of my admin page. I do not see Manage Packages,
> only load.
> *From:* Andy Morsell [mailto:amorsell at spatialgis.com]
> *Sent:* Wednesday, June 28, 2006 1:42 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* RE: [mapguide-users] Create Package
> The feature to create and load packages of trees within an
> existing repository is in the latest Open Source release.  Make sure
> you have the latest release from the MGOS web site.
> That functionality is in the Admin interface, then go to Manage
> Packages and the Make Package option at the top.  This feature was
> created specifically for this scenario: when you want to copy all or
> portions of an existing repository to a different server.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> *From:* Berdel, Brian [mailto:brian.berdel at mcmtrans.com]
> *Sent:* Wednesday, June 28, 2006 10:35 AM
> I am using the Open Source Version and the only option I have is to
> Load Packages.  Maybe it is a limitation of the Open Source Version?
> *From:* Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
> *Sent:* Wednesday, June 28, 2006 1:23 PM
> Which version are you using?  In the version I have, I go to the
> mapadmin sand there is an option to Manage Packages.  There I can
> package my entire site and bring it over to my production server.  I'm
> using the Enterprise version from the myfeedback Autodesk site.
> - Juan
> *Sent:* Wednesday, June 28, 2006 1:07 PM
> *Subject:* [mapguide-users] Create Package
> How do you create a package (If I wanted to transfer the data to a
> different server)?
> Thanks!
> *From:* Andrew DeMerchant [mailto:andrew.demerchant at gemtec.ca]
> *Sent:* Wednesday, June 28, 2006 10:41 AM
> *Subject:* Re: [mapguide-users] OSGeo FDO problem...
> No filter...
> Traian Stanev wrote:
> Hmm. It could be that the provider is being careless with filter
> conversion to string. Do you have a filter set on the layer, or are
> you simply trying to preview the whole layer with no filter?
> *Sent:* Wednesday, June 28, 2006 9:59 AM
> *To:* users at mapguide.osgeo.org <mailto:users at mapguide.osgeo.org>
> I'd love to try that, but where do I have that option? I'm using
> Studio...I see no place to either use an SQL statement of my own, or
> to put anything (let alone quotes) around a table name.
> Andrew
> Robert Fortin wrote:
> Andrew,
> Have you tried using single quote around you table name/column?
> RF
> *Sent:* Wednesday, June 28, 2006 9:24 AM
> *Subject:* [mapguide-users] OSGeo FDO problem...
> It seems that the OSGeo FDO provider doesn't like spaces in table
> names. The error log said that the FDO was causing a "Syntax error in
> FROM clause". Is this something that can be fixed? It should be a
> pretty simple fix, really..since I'd guess that all that needs to be
> done is to enclose table names (and field names, for that matter) in
> square brackets (ie, [Table Name], or [Table Name].[Field Name]). The
> work around for me for now is to make another Access database and link
> all of the tables from my real database. In this new database, I just
> rename the tables to get rid of the spaces. But I can't really rely on
> his workaround, because having to change table names means changing a
> lot of other things for other projects (this database is used in a lot
> of other ways, not just MapGuide). Is there any chance that this FDO
> can get modified to account for these spaces?
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-4GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
> *Andrew DeMerchant*
> fax 506-453-9470
> /191 Doak Road
> E3C 2E6
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users
