[mapguide-users] Studio Preview
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Jun 29 16:02:47 EDT 2006
I had a similar problem yesterday, and for me it was a problem with my
themed layer. It was like Ben says....so I'd check your themed layer(s)
and make sure that they're ok. Sounds like there's something wrong with
one of them.
Andrew
Ben Trumbore wrote:
> Chris,
> These error messages remind me of a problem that has been fixed for
> the next release.  That problem involved dynamic generation of the
> legend in the AJAX viewer for a themed layer where a style rule filter
> included quotes around a property name.  If you turn the legend off in
> your map, does the problem still happen?  Does the map preview alright
> with the DWF viewer?  Are there quoted property names in the style rules?
>    Ben
> *From:* Chris Tallman [mailto:ctallman at innomap.com]
> *Sent:* Thursday, June 29, 2006 3:37 PM
> *To:* users at mapguide.osgeo.org
> *Subject:* RE: [mapguide-users] Studio Preview
> rebooted again just to make sure and I still get this
> Which is a different error than before.  Any ideas on this one?
> I click yes to the one above and I get this one
> which is different from the one about it and the first one.
> Click yes to this one and I still don't see a preview.
> I have the same layer in another map based on the same shp and
> database it previews fine.  The two are even themed the same way.
> Basically the same layers just different coordinate systems.  What
> boggles the mind is it worked fine yesterday.
> Chris
> *From:* Dave Wilson [mailto:dave.wilson at autodesk.com]
> *Sent:* Thursday, June 29, 2006 2:58 PM
> Have you tried all the obvious things like restart Studio, restart IIS
> or a full reboot?
> Dave
> *Sent:* Thursday, June 29, 2006 12:48 PM
> Everything is on the same computer.
> Chris
> *Sent:* Thursday, June 29, 2006 2:45 PM
> Is studio on your server machine?
> What if you replace localhost with the machine name or IP Address if
> it isn't.
> Dave
> *Sent:* Thursday, June 29, 2006 12:41 PM
> I'm not.  I have my VD looking for port 8080 due to port forwarding
> from my external server.
> *Sent:* Thursday, June 29, 2006 2:39 PM
> How are you getting ASP to work under the apache port? Could this be
> your boo boo?
> Dave
> *Sent:* Thursday, June 29, 2006 11:00 AM
> *Subject:* [mapguide-users] Studio Preview
> Has anyone else seen this error?  I get it when I try and preview my
> layer in Studio.  Weird thing is I wasn't getting this error yesterday
> and as far as I know nothing has changed.
> **Chris Tallman**
> 260.407.1761
	*Andrew DeMerchant*
*Computer Technologist*
ph.1-877-4GEMTEC x.163
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
Fredericton, NB, Canada
E3C 2E6
Skipped content of type multipart/related
More information about the Mapguide-users mailing list
