[mapguide-users] AJAX Viewer and Tooltips
Andy Morsell
amorsell at spatialgis.com
Fri Mar 10 13:53:31 EST 2006
Yes, that seems to be the same bug I am seeing. I had not made the
correlation that it was only lines and points exhibiting the problem, but it
makes sense now. I still see occasional problems where objects can't be
selected when they should, but reloading the web layout fixes that.
Andy
_____
From: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Sent: Thursday, March 09, 2006 9:19 PM
Subject: RE: [mapguide-users] AJAX Viewer and Tooltips
Andy,
Artifact MG84 (https://mapguide.osgeo.org/servlets/Scarab/id/MG74) deals
with an AJAX viewer tooltip defect for layers containing point / polyline
data. Is this, by chance, the same problem you're seeing? We expect to
have a fix in place for this shortly.
Walt
_____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Thursday, March 09, 2006 8:23 PM
Subject: [mapguide-users] AJAX Viewer and Tooltips
I am still experiencing very unexpected behavior when more than one layer in
a map is selectable or has tooltips with the AJAX viewer. It seems that
layers don't obey their priority, some don't display tooltips at all, etc.
The DWF viewer seems to work as expected. Can others confirm that there are
still issues with this in R1.0?
Thanks.
Andy Morsell, P.E.
Spatial Integrators, Inc.
<http://www.SpatialGIS.com> http://www.SpatialGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060310/b14c8192/attachment.html
More information about the Mapguide-users
