[mapguide-users] New configuration problems
Eric Brown
ericbrown at netxn.com
Sun Mar 12 12:23:33 EST 2006
Bill,
Thanks - that's very strange. Somehow I downloaded Mapserver studio instead of Mapguide studio. Perhaps I'm confused - I'm under the impression that Mapguide Open Source server is really Mapserver. At any rate, I was somehow able to download Mapserver Studio (which has the exact same size footprint and file name as Mapguide Studio).
Please advise,
-- Eric
----- Original Message -----
To: users at mapguide.osgeo.org ; ericbrown at netxn.xom
Sent: Sunday, March 12, 2006 5:40 AM
Subject: RE: [mapguide-users] New configuration problems
Hi Eric,
The "version is incompatible" message probably means that you have an old Studio. A new one got posted last week to www.autodesk.com/mapguidestudio with a version number of 1.0.0.16407 (you can use the Help About dialog to confirm the version). If you download and install the new one, that should fix your problem
Bill
Sent: Sunday, March 12, 2006 8:35 AM
To: users at mapguide.osgeo.org; ericbrown at netxn.xom
Hi Eric,
The mgp file itself is just a zip file containing all the map resources. Sometimes Internet Explorer changes the extensions of files it recognizes, so it likely renamed it to .zip when it downloaded it. Just rename it to .mgp.
As far as the Studio problem, let's wait for someone else (who knows better) to answer that. But I am puzzled that you say MapServer Studio... That's what the 0.9 version was called, the current one should say MapGuide Studio when it starts up.
Traian
-----Original Message-----
Sent: Sun 3/12/2006 3:14 AM
Cc:
Subject: [mapguide-users] New configuration problems
All...
Just downloaded MapGuide & Mapserver Studio.
While the Admin appears to function fairly properly - I can't connect from studio, receiving the following message: "The Studio version is incompatible with the site version."
Since I downloaded both files today my assumption would be that all would be synched properly.
Additionally, though I believe these may be related based on other posts.. the sheboygan.mgp download file isn't a .mgp but rather a .zip file doesn't include a the sheboygan.mgp file. And I've tried just putting the .zip file in the C:\Program Files\MapGuideOpenSource\Server\Packages folder to no avail, the admin doesn't see a package.
So.. I'm at somewhat of an impasse because I can't get the demo apps to run because of no data, and I can't play with the development tool due to a version conflict.
Any assistance would be greatly appreciated.
-- Eric
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060312/c81bba19/attachment.html
More information about the Mapguide-users
