[mapguide-users] Hidden Information - Installing Adsk MapStudioPreview
Francisco Javier Rojas Duran
francisco.rojas at dasoft.com.mx
Mon Mar 13 12:34:40 EST 2006
Hi Traian:
I post that issue for Autodesk Support and they sent me one week ago the
same workaround (REGISTRY) by creating a Culture entry on
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Autodesk MapGuide Studio\1.0.0.16407\
But It did not work, Map Studio Preview Gives Me and Error Unable to
complete the request to server Argument is null.
This Error happens on Windows 2000/2003 Spanish OS with MapStudio March
Preview. So consider this issue for the next release of Adsk MapStudio.
Best Regards.
CSE Francisco Javier Rojas Durán
IT Manager - Oracle Specialist
Grupo DaSoft S.A. de C.V.
_____
De: Traian Stanev [mailto:traian.stanev at autodesk.com]
Enviado el: Lunes, 13 de Marzo de 2006 10:05 a.m.
Para: users at mapguide.osgeo.org
Asunto: RE: [mapguide-users] Hidden Information - Installing Adsk
MapStudioPreview
Hi Francisco,
Did you try the solution suggested by Bill Dhimitri in an earlier posting to
this list ("Locale issue with MapGuide Studio")?
Here is the solution again:
To work around this problem, create a DWORD Value entry named Culture with a
decimal value of 1033 in this registry folder:
I have attached a reg file that will add this entry to your registry.
You can look up that message if you would like to use the reg file to create
that registry entry.
-- Traian
_____
From: Francisco Javier Rojas Duran [mailto:francisco.rojas at dasoft.com.mx]
Sent: Monday, March 13, 2006 10:38 AM
Cc: users-digest at mapguide.osgeo.org
Subject: [mapguide-users] Hidden Information - Installing Adsk
MapStudioPreview
Hi Everybody:
We were having a lot of problems with MapServer Enterprise, after few weeks
we found that TuX Preview 1 was more flexible and complete (because of the
FDO Providers including Oracle) excepting for the AJAX Viewer (NOT INCLUDED
WITH THAT PREVIEW, ONLY DWF) than MapServer Enterprise 0.9.1, and then we
found that MapGuide OpenSource 1.0 RC1 is more reliable than the previous
version 0.9.1 so everyone should migrate from 0.9.1 to 1.0 and the platform
language does not matter for the Server and Web Tier (We Tested on Spanish
OS) , UNLESS YOU RUN MapStudio March Preview because if you are running a
NON-ENGLISH Windows Server and you run MapStudio on the same computer, and
try to use it with MapGuide OS , it fails in almost all the commands or
create procedures.
Neither Autodesk or OSGeo know the issue, so BE CAREFUL of using MapStudio
on a NON-ENGLISH Windows Server/Pro (2000/XP/2003).
Also the old guide for deploying Map Guide OS Sample Web Apps is the same
for the 1.0 version, so OSGeo must ADVICE that a Guide and more
documentation is needed to be post on the web site.
Finally we have the software working fine on Windows 2000 Advanced Server
SP4(English) and Windows 2003 Standard Server SP1 (Spanish) with Adsk Map 3D
2007 Alpha 2.
The Next Question is : How MapGuide OS can interact with Google Earth?
Best Regards,
CSE Francisco Rojas
Grupo DaSoft SA de CV
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060313/6a0a5168/attachment.html
More information about the Mapguide-users
