[mapguide-users] Lat Long Display Issue/Bug
Alain Lebatard
alain.lebatard at autodesk.com
Wed Mar 15 16:57:48 EST 2006
SetSelectionXML() behaves differently in the context of the DWF viewer
than in the context of the AJAX viewer. The DWF viewer surround
implementation first selects the features then performs a zoom to the
selection extent, and the AJAX code does not, it just select the
features.
The AJAX implementation is correct; selecting features should not cause
a zoom. The DWF function will be fixed.
Alain
-----Original Message-----
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Wednesday, March 15, 2006 1:48 PM
Subject: RE: [mapguide-users] Lat Long Display Issue/Bug
Thanks for the tip, Kori. As for my below described potential
work-around,
I just tried it with the DWF viewer (I've been exclusively using the
AJAX
viewer) and the selection does not work. It works fine with the AJAX
viewer, however. I'll track that one down some day.......
Andy
Sent: Wednesday, March 15, 2006 1:01 PM
Thanks Andy,
If I call a ZoomToView after the SetSelectionXml it works fine.
I send my well formed XML with the String.Format function. As long the
parameter {0} is enclosed with single quotes '{0}' it works no problem.
i.e.
Dim l_sJavascript As String = String.Format("ZoomSelection( {0}, {1},
'2000', '{2}' );", l_oMGCoordinateXY.GetX(), l_oMGCoordinateXY.GetY(),
selectionXML)
Then register it as a startupscript...
Kori Maleski BSc.
Senior Technical Consultant
Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1 TEL
403.770.1917
FAX
877.691.9149
TOL
877.691.9171
www.pat.ca
Sent: March 15, 2006 1:44 PM
It definitely sounds like something funky with SetSelectionXml. When I
first did this, I was trying to use SetSelectionXml and had some issues
getting it to accept my programatically formed XML. So, I ended up
doing
things a bit differently. Since I was already having to get a FeatID
for an
object based on another field, I then have the program create a new
MgSelection, add my object to it using the AddFeatureIdInt32 method,
then
Save it. This way you don't have to mess with passing well-formed XML
from
server to client. If you then use ZoomToView after this, it will zoom
to
that location and use the selection that has been saved on the server
when
the view is refreshed.
Perhaps something similar will help you work around the problem.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
Sent: Wednesday, March 15, 2006 12:27 PM
Hi Andy,
If I fire XML to the SetSelectionXML function, it selects the parcel,
and
zooms to latlong coordinates in the XY projection.
So instead of X 100000 Y 1000000, it says X -122.000 Y 48.00000. Note
the
XYs. So the map ends up in the far left lower corner of the map.
I am not calling any zoom function when I am doing this.
If I fire the SetSelectionXML function, then the ZoomToView function
followed by a Refresh - it will select and end up in the correct place.
The ZoomToView function in this case is being passed projected
coordinates.
Is my SetSelectionXML doing something funky?
Kori Maleski BSc.
403.770.1917
FAX
877.691.9149
TOL
877.691.9171
www.pat.ca
Sent: March 15, 2006 1:14 PM
I have some similar custom programming, but no coordinate
transformation,
and setSelectionXml does not zoom to the selection automatically. If
you
alert your x and y coordinates being passed to ZoomToView, are they
pre-projected or post-projected? It's odd that you can get to it work
when
SetSelectionXml is not involved since the selection does not have a
coordinate element, only elements for the layer and the object (via the
internal feature ID).
Andy Morsell, P.E.
Sent: Wednesday, March 15, 2006 11:57 AM
Thanks Alain,
Here is the real bug then:
Map is projected.
Washington State Plane NAD27 North (ft)
Data is geographic WGS 84
I have a ZoomToView function that reads from a point database with
LatLong
columns.
I use the MGProjection/Factory etc. to translate these point positions
to
the proper projection.
Send the new coordinates to the ZoomToView.
Works like a charm.
Now:
I want to pass my selection in XML to the SetSelectionXML.
I create an MGSelection object querying a LatLong Parcel Layer in the
Projected Map.
Passes it...
It then selects my feature and zooms to a LatLong position on the XY
projected map (somewhere far far away.
So. 2 Questions:
Does the SetSelectionXML function zoom to its selection automatically?
Why is it zooming to latlong coordinates when the map is projected?
I believe this is a serious bug, unless I am out to lunch somehow...
Kori Maleski BSc.
403.770.1917
FAX
877.691.9149
TOL
877.691.9171
www.pat.ca
From: Alain Lebatard [mailto:alain.lebatard at autodesk.com]
Sent: March 15, 2006 12:32 PM
Hi Kori,
This is a bug that only affects the display of the coordinates. The
order of
the parameters in the ZoomToView function has always the same meaning,
regardless of the display settings, so do not switch the Lat and Lon
values
in the call to this API.
Alain
Sent: Wednesday, March 15, 2006 10:05 AM
Subject: [mapguide-users] Lat Long Display Issue/Bug
Hi All,
I have a map that I am displaying in Washington State Plane NAD27 North
(ft)
projection and the DWF viewer is switching the Lat for Lon in the
coordinate
display.
Anyone else see this? Does this mean we have to switch them for the
ZoomToView function as well?
Cheers,
Kori Maleski BSc.
403.770.1917
FAX
877.691.9149
TOL
877.691.9171
www.pat.ca
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
