[mapguide-users] Build error in MapGuide Oem Components [was: Build error in Oem Components of fdo-3.0.0_G001.tar.gz]
Sacha Genoud s.genoud at mkreis.ch
Thu Mar 16 11:07:28 EST 2006
Hello Walt
i've the file changed, but now appears a new error:
make[11]: Entering directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf/package/writer/extens
ions'
avoid-version
../../../package/writer/extensions/6.01/libdwfpackagewriterextensions601.la
sions/6.0/libdwfpackagewriterextensions60.la -lz
make[11]: avoid-version: Kommando nicht gefunden
make[11]: [libdwfpackagewriterextensions.la] Fehler 127 (ignoriert)
make[11]: Leaving directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf/package/writer/extensi
ons'
make[10]: Leaving directory
ons'
make[10]: Entering directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf/package/writer'
make[10]: *** Keine Regel vorhanden, um das Target
»../../package/writer/extensions/libdwfpackagewriterextensions.la«,
  benötigt von »libdwfpackagewriter.la«, zu erstellen.  Schluss.
make[9]: *** [all-recursive] Fehler 1
make[9]: Leaving directory
make[8]: *** [all-recursive] Fehler 1
make[8]: Leaving directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf/package'
make[7]: *** [all-recursive] Fehler 1
make[7]: Leaving directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf'
make[6]: *** [all-recursive-am] Fehler 2
make[6]: Leaving directory
make[5]: *** [all-recursive] Fehler 1
make[5]: Leaving directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src'
make[4]: *** [all-recursive] Fehler 1
make[4]: Leaving directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global'
make[3]: *** [all-recursive] Fehler 1
make[3]: Leaving directory
`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop'
make[2]: *** [all-recursive] Fehler 1
make[2]: Leaving directory `/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1'
make[1]: *** [all-recursive] Fehler 1
make[1]: Leaving directory `/mapguide/install/mapguide-1.0.0/Oem'
make: *** [all-recursive] Fehler 1
Sacha
Walt Welton-Lair schrieb:
>Some progress on this:
>1/ Open PackageVersionExtension.h and add the following lines near the top:
>#ifdef minor
>#undef minor
>#endif
>#ifdef major
>#undef major
>#endif
>2/ Go to the OEM/DWFTK7.1/develop/global/src/dwf folder and open configure.in.  Find the two occurrences of "-pedantic" and remove them (but not "-pedantic-errors").
>3/ Rerun build_oem.sh.  The DWF components should now build.
>BTW, the fixes for this have been submitted - see https://mapguide.osgeo.org/servlets/Scarab/id/MG90.
>Walt
>-----Original Message-----
>From: Sacha Genoud [mailto:s.genoud at mkreis.ch]
>Sent: Tuesday, March 14, 2006 2:57 AM
>To: users at mapguide.osgeo.org
>Subject: Re: [mapguide-users] Build error in MapGuide Oem Components [was: Build error in Oem Components of fdo-3.0.0_G001.tar.gz]
>Hi Nicol
>i think we have a similarly problem. I am also on a Debian box.
>In file included from ../../../dwf/package/writer/PackageWriter.h:42,
>                 from ../../../dwf/package/Units.h:31,
>                 from
>../../../dwf/package/reader/EModelSectionDescriptorReader.
>h:33,
>                 from EModelSectionDescriptorReader.cpp:21:
>../../../dwf/package/writer/PackageVersionExtension.h:96: error: parse error
>   before `int'
>../../../dwf/package/writer/PackageVersionExtension.h:106: error: parse
>error   before `int'
>make[9]: *** [EModelSectionDescriptorReader.lo] Fehler 1
>`/mapguide/install/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf/package/reader'
>gcc (GCC) 3.3.5 (Debian 1:3.3.5-13)
>If you find a solution......  .
>Thanks
>Sacha
>Nicol Hermann schrieb:
>>Hi Traian,
>>many thanks for your help. You are absolutely right. I refer to the Oem
>>Components in the Mapguide 1.0.0 distribution. Sorry for the confusion.
>>Your patch fixes my problem. Sadly i get a new one. See below.
>>These compiling errors are difficult to recognise because the build
>>script (build_oem.sh) do not stop when the error occur.
>>Is there a way to move this process under the control of the
>>general ./configure script?
>>Attaches the new error.
>>g++ -DHAVE_CONFIG_H -I../../.. -g0 -O2 -pipe -pedantic -Wall
>>-Wno-long-long -Wnon-virtual-dtor -Wsign-promo -Wsign-compare -Wundef
>>-Wstrict-prototypes -fforce-addr -fomit-frame-pointer -finline-functions
>>-ffast-math -fno-strict-aliasing -c EModelSectionDescriptorReader.cpp
>>-MT EModelSectionDescriptorReader.lo -MD -MP
>>-MF .deps/EModelSectionDescriptorReader.TPlo  -fPIC
>>-DPIC-o .libs/EModelSectionDescriptorReader.o
>>from ../../../dwf/package/reader/EModelSectionDescriptorReader.h:33,
>>error
>>  before `int'
>>error
>>  before `int'
>>make[3]: *** [EModelSectionDescriptorReader.lo] Fehler 1
>>`/home/nicol/public_html/foundation/source/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf/package/reader'
>>`/home/nicol/public_html/foundation/source/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf/package'
>>`/home/nicol/public_html/foundation/source/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src/dwf'
>>make: *** [all] Fehler 2
>>Many thanks
>>Nicol
>>>Hi,
>>>You say you are building FDO, but the error happened when building the
>>>DWF toolkit, which is part of MapGuide. Did you build FDO already and
>>>are now compiling MapGuide? Anyway, I fixed this in subversion, and
>>>here is the relevant diff for the file (line 155 and onwards).
>>>--- UUID.cpp    (revision 276)
>>>+++ UUID.cpp    (working copy)
>>>@@ -152,10 +152,10 @@
>>>    // cccccccc-bbbb-1aaa
>>>    // note the 1 indicates a time-based uuid with a known or random
>>>host id
>>>-    nTimestamp = ((nTimestamp << 32) & 0xffffffff00000000) |
>>>-                 ((nTimestamp >> 16) & 0x00000000ffff0000) |
>>>-                 ((nTimestamp >> 48) & 0x0000000000000fff) |
>>>-                                       0x0000000000001000;
>>>+    nTimestamp = ((nTimestamp << 32) & 0xffffffff00000000LL) |
>>>+                 ((nTimestamp >> 16) & 0x00000000ffff0000LL) |
>>>+                 ((nTimestamp >> 48) & 0x0000000000000fffLL) |
>>>+                                       0x0000000000001000LL;
>>>It's strange that it compiles fine on 3.2.3 and 4.0.2 but not on the
>>>one in the middle (3.3).
>>>Traian
>>From: Nicol Hermann [mailto:mapserver at geoworld.de]
>>Sent: Friday, March 10, 2006 6:50 AM
>>Subject: [mapguide-users] Build error in Oem Components of
>>Hi List,
>>it tried to build the new fdo release (fdo-3.0.0_G001.tar.gz) on my
>>debian 32 bit sarge box.
>>During the compilation of the Oem product 'Oem/DWFTK7.1' with
>>build_oem.sh the following error occurred.
>>make[2]: Entering directory
>>evelop/global/src/dwfcore/ansi'
>>source='UUID.cpp' object='UUID.lo' libtool=yes \
>>depfile='.deps/UUID.Plo' tmpdepfile='.deps/UUID.TPlo' \
>>depmode=gcc3 /bin/sh ../depcomp \
>>/bin/sh ../libtool --mode=compile g++ -DHAVE_CONFIG_H  -I../..    -g0
>>-O2 -pipe -pedantic -Wall -Wno-long-long  -Wnon-virtual-dtor
>>-Wsign-promo -Wsign-compare -Wundef -Wstrict-prototypes -fforce-addr
>>-fomit-frame-pointer -finline-functions -ffast-math -fno-strict-aliasing
>>-c-o UUID.lo `test -f 'UUID.cpp' || echo './'`UUID.cpp
>>g++ -DHAVE_CONFIG_H -I../.. -g0 -O2 -pipe -pedantic -Wall
>>-ffast-math -fno-strict-aliasing -c UUID.cpp -MT UUID.lo -MD -MP
>>-MF .deps/UUID.TPlo  -fPIC -DPIC -o .libs/UUID.o
>>UUID.cpp: In member function `void
>>DWFCore::DWFUUIDImpl_ANSI::_generate()':
>>UUID.cpp:155: error: integer constant is too large for "long" type
>>make[2]: *** [UUID.lo] Fehler 1
>>Does anyone know how to fix this?
>>gcc --version
>>Many thanks
>>Nicol
>>To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
