[mapguide-users] dynamic label rotation
Sacha Genoud s.genoud at mkreis.ch
Fri Mar 17 04:04:12 EST 2006
It is a point layer and the attribute is  a number. I have the file
attached.
Traian Stanev schrieb:
>What kind of layer is it -- point, polygon or line? What kind of property is it -- string, number?
>-----Original Message-----
>From: Sacha Genoud [mailto:s.genoud at mkreis.ch]
>Sent: Thursday, March 16, 2006 4:04 AM
>To: users at mapguide.osgeo.org
>Subject: Re: [mapguide-users] dynamic label rotation
>Hi Traian,
>that is what i have done, but it does not work. I have checkt the file
>and the values in the file
>are ok. Is it a bug?
>Thanks!
>Sacha
>>Hi,
>>You need to pick "Expression" in the Rotation listbox when setting up
>>the style. See attached screenshot. This will let you base rotation
>>angle on a property value from your data source.
>>Traian
>>Sent: Wednesday, March 15, 2006 8:28 AM
>>Subject: [mapguide-users] dynamic label rotation
>>can labels rotated with a value from a shp file in mapguide studio? it
>>works only
>>with static vlaues?
>>Sacha
>>To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
>>For additional commands, e-mail: users-help at mapguide.osgeo.org
Gruss
Sacha
Kreis AG Sargans
Ingenieur- und Vermessungsbüro
Kantonsschulweg 12
CH-7320 Sargans(Hauptbetrieb)
Tel. +41 (0)81 720 05 00
Fax +41 (0)81 720 05 05
Homepage : http://www.mkreis.ch
E-Mail   : mailto:s.genoud at mkreis.ch
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060317/f439f86a/test_strassen_name.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060317/f439f86a/test_strassen_name-0001.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060317/f439f86a/test_strassen_name-0002.obj
More information about the Mapguide-users mailing list
