[mapguide-users] Dynamic Maps
Kori Maleski km at pat.ca
Fri Mar 17 21:03:18 EST 2006
The Web API allows for the dynamic layer creation.  Dynamic everything.
Create a layer - add it to the map - save the map - presto.
There is a sample in the MapGuide Developers Guide:
https://mapguide.osgeo.org/docs/MapGuideDevGuide.pdf
Cheers,
Kori Maleski  BSc.
Senior Technical Consultant
Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1
TEL
403.770.1917
FAX
877.691.9149
 TOL
877.691.9171
www.pat.ca
________________________________________
From: Steven J Reed [mailto:sjreed at edcomputing.com]
Sent: March 17, 2006 6:36 PM
Subject: [mapguide-users] Dynamic Maps
My MapGuide 6.5 application dynamically creates layers (SDFs) from external
databases, adding them to the display and to the MWX file which is turned
back into the MWF for later use.  Symbols are also added to the MWX as
needed.
Is there a capability within the New MapGuide to dynamically create layers?
Everything I read talks about pre-defined ‘Resources’, so maybe there’s a
means (through an API?) to dynamically add resources.
I’d appreciate anyone pointing me in the right direction to make this
happen!
Thanks
Steve
Steven J. Reed
El Dorado Computing
P. O. Box 5745
Stateline, NV   89449-5745
(775) 589-6850   (916) 226-9065 Fax: (503) 218-7622
More information about the Mapguide-users mailing list
