[mapguide-users] Mapguide Service not starting automatically
Butler, Juan P jpbutler at co.pinellas.fl.us
Mon Mar 20 13:42:29 EST 2006
Bruce:
Nothing in the Error.log, but other errors.  I need to get these errors
looked at too.  I'll start a new thread.
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
From: Bruce Dechant [mailto:bruce.dechant at autodesk.com]
Sent: Monday, March 20, 2006 11:46 AM
Subject: RE: [mapguide-users] Mapguide Service not starting
automatically
Juan,
Is there any information in the MapGuide "Error.log" that might indicate
why the service failed to start?
Could you also try running the server from the command line to see if
that works? (I'm just trying to see if the server can actually startup
properly)
To start the server from the command line do the following:
1)       Open a "Command Prompt" windows
2)       Change to the directory where the server is installed. Default
is here: C:\Program Files\Autodesk\MapGuideEnterprise2007\Server\Bin
3)       At the command prompt type "mgserver /interactive" without the
double quotes.
The server should indicate it has started. If it does not please have a
look in the "Logs" folder of C:\Program
Files\Autodesk\MapGuideEnterprise2007\Server and check the "Error.log"
file for the reason why the server could not start.
Please let me know what happens after trying the above.
Thanks,
Bruce
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Monday, March 20, 2006 8:26 AM
Subject: [mapguide-users] Mapguide Service not starting automatically
Is anyone running into an issue when restarting their server or in my
case laptop, and the Mapguide Service not automatically starting on
reboot?  It's set to automatic.
Thanks.
Juan Butler
jpbutler at pinellascounty.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060320/755ea504/attachment.html
More information about the Mapguide-users mailing list
