[mapguide-users] MapGuide Install question
Francisco Javier Rojas Duran francisco.rojas at dasoft.com.mx
Tue Mar 21 12:06:14 EST 2006
Be Careful, MapGuide OpenSource needs Autodesk DWF Viewer 6.5 , and Autodesk
MapGuide needs Autodesk MapGuide Viewer 6.5 , It is not the same
Viewer / plug - inn.
And you can have installed both of them (The Viewers only).
Regards.
Ing. Francisco Javier Rojas Durán
IT Manager - Oracle Specialist
Division de Tecnologias de Información
Grupo DaSoft S.A. de C.V.
-----Mensaje original-----
De: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Enviado el: Lunes, 20 de Marzo de 2006 06:13 p.m.
Para: users at mapguide.osgeo.org
Asunto: RE: [mapguide-users] MapGuide Install question
v6.5 is the latest DWF Viewer
	-----Original Message-----
	Sent: Mon 3/20/2006 6:56 PM
	Cc:
	Subject: RE: [mapguide-users] MapGuide Install question
	Yes - completely uninstall the old MapServer Enterprise.
	Make a backup of any folders if you need to.
	The un-install of the 6.5 ActiveX control is not necessary.
	You will want to install the lastest DWF viewer though...
	Kori Maleski  BSc.
	Senior Technical Consultant
	Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1
	TEL
	403.770.1917
	FAX
	877.691.9149
	 TOL
	877.691.9171
	www.pat.ca
	________________________________________
	From: Randy Glen Johnson [mailto:rjohnson at maintenanceconnection.com]
	Sent: March 20, 2006 3:55 PM
	Subject: [mapguide-users] MapGuide Install question
	Do I need to uninstall MapServer Enterprise Server/Web Extensions
before
	installing MapGuide Server/Web Extensions?
	And what about the older version of Autodesk’s MapServer Studio?
Uninstall
	first?
	And Autodesk Mapguide Viewer Active X control Version 6.5?
	Best Regards,
	Randy Glen Johnson
	Programmer Analyst
	Maintenance Connection, Inc.
	1-888-567-3434 ext 800
	http://www.maintenanceconnection.com
	To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
	For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
