[mapguide-users] Custom layouts...
Andy Morsell
amorsell at spatialgis.com
Tue Mar 21 15:10:56 EST 2006
I thought that Autodesk was looking at making a locator/inset map an
additional web layout component. It really seems like it should be a
standard element.
Andy
-----Original Message-----
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Tuesday, March 21, 2006 11:58 AM
Subject: RE: [mapguide-users] Custom layouts...
I wonder if there is some way I could modify the template to:
- move the legend iframe to the same area as the task results area and
- add an inset map
I'm thinking that I could add a button to the toolbar area that when clicked
toggles between legend display and the task results area. I would also have
to provide an override to the selection action, displaying the results in
the task area. This would allow me to have a single panel for
legend/tasks/identify results, with a box at the bottom for an inset map,
maximizing the screen space. I'd also like to see about adding a
"show/hide" button that collapses and expands the task/inset frame.
Ideally, this would be a graphical indicator attached to the frame like in
Dreamweaver or Visual Studio.
If I can do these changes in a fairly generic way, then I don't have to
worry about making global changes to the template, as they'll be globally
useful. Then I only have to worry about re-integrating the changes with new
MapGuide releases...
Using the Studio authoring environment and the default layout eases
maintenance and development time, but our users have become accustomed to a
custom surround. Besides, we don't want to be boring :)
It would be nice if, since this app requires PHP, we could move to using
Smarty or PHPTemplate or something like that for generating the pages, with
a method of selecting the template to be used with each layout.
This would allow for easier customisation.
Jason
Sent: Tuesday, March 21, 2006 11:42
I am not quite there yet...
I have had issues with trying to put an inset map in the Task Panel
because of the Task panel Page reloading. An IFRAME would be the
easiest way - as it would mean not modifying the Frames. You would have
to put in a Red Line function to draw the map reference area in the
inset map that would have to be called when the map view changed,
requiring another modification to the mainframe.templ.
I will probably start working on this next week.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
