[mapguide-users] make errors building web exstentions
Walt Welton-Lair walt.welton-lair at autodesk.com
Tue Mar 21 17:07:32 EST 2006
The errors appear to be jpeg-related.  Do you have the jpeg package
installed on your machine?  It's required...
  _____
From: Bas van den Dikkenberg [mailto:bas at giskit.nl]
Sent: Tuesday, March 21, 2006 5:04 PM
Subject: [mapguide-users] make errors building web exstentions
If have run the following command  a cording to manual
./build_oem.sh
Then ./configure --enable-server=no still no errors
When I run make I get following error wat am I doing wrong?
/usr/bin/install -c -m 644 'macro_draw.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/macro_draw.h'
 /usr/bin/install -c -m 644 'macro_scale.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/macro_scale.h'
 /usr/bin/install -c -m 644 'macro_index.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/macro_index.h'
 /usr/bin/install -c -m 644 'marksize.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/marksize.h'
 /usr/bin/install -c -m 644 'marksymb.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/marksymb.h'
 /usr/bin/install -c -m 644 'matrix.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/matrix.h'
 /usr/bin/install -c -m 644 'merge_control.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/merge_control.h'
 /usr/bin/install -c -m 644 'named_view.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/named_view.h'
 /usr/bin/install -c -m 644 'named_view_list.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/named_view_list.h'
 /usr/bin/install -c -m 644 'object.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/object.h'
 /usr/bin/install -c -m 644 'object_node.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/object_node.h'
 /usr/bin/install -c -m 644 'object_node_list.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/object_node_list.h'
 /usr/bin/install -c -m 644 'object_stream.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/object_stream.h'
 /usr/bin/install -c -m 644 'opcode.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/opcode.h'
 /usr/bin/install -c -m 644 'opcode_defs.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/opcode_defs.h'
 /usr/bin/install -c -m 644 'origin.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/origin.h'
 /usr/bin/install -c -m 644 'overpost.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/overpost.h'
 /usr/bin/install -c -m 644 'palette.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/palette.h'
 /usr/bin/install -c -m 644 'pattern_scale.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/pattern_scale.h'
 /usr/bin/install -c -m 644 'pch.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/pch.h'
 /usr/bin/install -c -m 644 'penpat.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/penpat.h'
 /usr/bin/install -c -m 644 'penpat_options.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/penpat_options.h'
 /usr/bin/install -c -m 644 'plot_optimized.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/plot_optimized.h'
 /usr/bin/install -c -m 644 'plotinfo.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/plotinfo.h'
 /usr/bin/install -c -m 644 'pnggroup4image.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/pnggroup4image.h'
 /usr/bin/install -c -m 644 'point.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/point.h'
 /usr/bin/install -c -m 644 'pointset.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/pointset.h'
 /usr/bin/install -c -m 644 'polygon.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/polygon.h'
 /usr/bin/install -c -m 644 'polyline.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/polyline.h'
 /usr/bin/install -c -m 644 'polymark.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/polymark.h'
 /usr/bin/install -c -m 644 'polytri.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/polytri.h'
 /usr/bin/install -c -m 644 'preload.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/preload.h'
 /usr/bin/install -c -m 644 'projection.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/projection.h'
 /usr/bin/install -c -m 644 'rendition.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/rendition.h'
 /usr/bin/install -c -m 644 'rendopts.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/rendopts.h'
 /usr/bin/install -c -m 644 'resource.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/resource.h'
 /usr/bin/install -c -m 644 'rgb.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/rgb.h'
 /usr/bin/install -c -m 644 'signdata.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/signdata.h'
 /usr/bin/install -c -m 644 'text.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text.h'
 /usr/bin/install -c -m 644 'text_background.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text_background.h'
 /usr/bin/install -c -m 644 'text_options.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text_options.h'
 /usr/bin/install -c -m 644 'text_halign.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text_halign.h'
 /usr/bin/install -c -m 644 'text_valign.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text_valign.h'
 /usr/bin/install -c -m 644 'timestamp.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/timestamp.h'
 /usr/bin/install -c -m 644 'transform.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/transform.h'
 /usr/bin/install -c -m 644 'trusted_font_list.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/trusted_font_list.h'
 /usr/bin/install -c -m 644 'typedefs_defines.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/typedefs_defines.h'
 /usr/bin/install -c -m 644 'units.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/units.h'
 /usr/bin/install -c -m 644 'unknown.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/unknown.h'
 /usr/bin/install -c -m 644 'url.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/url.h'
 /usr/bin/install -c -m 644 'url_list.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/url_list.h'
 /usr/bin/install -c -m 644 'userdata.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/userdata.h'
 /usr/bin/install -c -m 644 'usrfillpat.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/usrfillpat.h'
 /usr/bin/install -c -m 644 'usrhatchpat.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/usrhatchpat.h'
 /usr/bin/install -c -m 644 'view.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/view.h'
 /usr/bin/install -c -m 644 'viewport.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/viewport.h'
 /usr/bin/install -c -m 644 'viewport_options.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/viewport_options.h'
 /usr/bin/install -c -m 644 'visible.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/visible.h'
 /usr/bin/install -c -m 644 'whip_toolkit.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/whip_toolkit.h'
 /usr/bin/install -c -m 644 'whipcore.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/whipcore.h'
 /usr/bin/install -c -m 644 'whiperrs.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/whiperrs.h'
 /usr/bin/install -c -m 644 'wtstring.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/wtstring.h'
 /usr/bin/install -c -m 644 'wversion.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/wversion.h'
 /usr/bin/install -c -m 644 'wendian.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/wendian.h'
make[8]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src
/dwf/whiptk'
make[7]: Leaving directory
/dwf/whiptk'
Making install in w3dtk
make[7]: Entering directory
/dwf/w3dtk'
Making install in jpeg
make[8]: Entering directory
/dwf/w3dtk/jpeg'
make[9]: Entering directory
/dwf/w3dtk/jpeg'
make[9]: Nothing to be done for `install-exec-am'.
test -z "/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg" || mkdir
-p -- "/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg"
 /usr/bin/install -c -m 644 'jchuff.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jchuff.h'
 /usr/bin/install -c -m 644 'jconfig.cfg'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.cfg'
 /usr/bin/install -c -m 644 'jconfig.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.h'
 /usr/bin/install -c -m 644 'jconfig.hpux'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.hpux'
 /usr/bin/install -c -m 644 'jconfig.irix'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.irix'
 /usr/bin/install -c -m 644 'jconfig.solaris'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.solaris'
 /usr/bin/install -c -m 644 'jconfig.vc'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.vc'
 /usr/bin/install -c -m 644 'jconfig.vms'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.vms'
 /usr/bin/install -c -m 644 'jdct.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jdct.h'
 /usr/bin/install -c -m 644 'jdhuff.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jdhuff.h'
 /usr/bin/install -c -m 644 'jerror.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jerror.h'
 /usr/bin/install -c -m 644 'jinclude.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jinclude.h'
 /usr/bin/install -c -m 644 'jmemsys.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jmemsys.h'
 /usr/bin/install -c -m 644 'jmorecfg.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jmorecfg.h'
 /usr/bin/install -c -m 644 'jpegint.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jpegint.h'
 /usr/bin/install -c -m 644 'jpeglib.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jpeglib.h'
 /usr/bin/install -c -m 644 'jversion.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jversion.h'
make[9]: Leaving directory
/dwf/w3dtk/jpeg'
/dwf/w3dtk/jpeg'
Making install in utility
/dwf/w3dtk/utility'
/dwf/w3dtk/utility'
test -z "/usr/local/mapguideopensource/include/dwf/w3dtk/utility" ||
mkdir -p -- "/usr/local/mapguideopensource/include/dwf/w3dtk/utility"
 /usr/bin/install -c -m 644 'varray.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/varray.h'
 /usr/bin/install -c -m 644 'vconf.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vconf.h'
 /usr/bin/install -c -m 644 'vhash.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vhash.h'
 /usr/bin/install -c -m 644 'vheap.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vheap.h'
 /usr/bin/install -c -m 644 'vlist.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vlist.h'
 /usr/bin/install -c -m 644 'vlogfile.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vlogfile.h'
/dwf/w3dtk/utility'
/dwf/w3dtk/utility'
Making install in hoops
/dwf/w3dtk/hoops'
/dwf/w3dtk/hoops'
test -z "/usr/local/mapguideopensource/include/dwf/w3dtk/hoops" || mkdir
-p -- "/usr/local/mapguideopensource/include/dwf/w3dtk/hoops"
 /usr/bin/install -c -m 644 'hoops_tools.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/hoops/hoops_tools.h'
 /usr/bin/install -c -m 644 'lod.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/hoops/lod.h'
/dwf/w3dtk/hoops'
/dwf/w3dtk/hoops'
/dwf/w3dtk'
if /bin/sh ../libtool --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H
-I../..   -DBSTREAM_DISABLE_REPULSE_COMPRESSION  -g0 -O2 -pipe -pedantic
-Wall -Wno-long-long  -Wnon-virtual-dtor -Wsign-promo -Wsign-compare
-Wundef -Wstrict-prototypes -fforce-addr -fomit-frame-pointer
-finline-functions -ffast-math -fno-strict-aliasing -MT
BOpcodeHandler.lo -MD -MP -MF ".deps/BOpcodeHandler.Tpo" -c -o
BOpcodeHandler.lo BOpcodeHandler.cpp; \
then mv -f ".deps/BOpcodeHandler.Tpo" ".deps/BOpcodeHandler.Plo"; else
rm -f ".deps/BOpcodeHandler.Tpo"; exit 1; fi
 g++ -DHAVE_CONFIG_H -I../.. -DBSTREAM_DISABLE_REPULSE_COMPRESSION -g0
-O2 -pipe -pedantic -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo
-Wsign-compare -Wundef -Wstrict-prototypes -fforce-addr
-fomit-frame-pointer -finline-functions -ffast-math -fno-strict-aliasing
-MT BOpcodeHandler.lo -MD -MP -MF .deps/BOpcodeHandler.Tpo -c
BOpcodeHandler.cpp  -fPIC -DPIC -o .libs/BOpcodeHandler.o
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
Ada/C/ObjC but not for C++
BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or directory
BOpcodeHandler.cpp:4948: error: field `jerr' has incomplete type
BOpcodeHandler.cpp:4954: error: variable or field `my_jpeg_messages'
declared void
BOpcodeHandler.cpp:4954: error: `j_common_ptr' was not declared in this
scope
BOpcodeHandler.cpp:4954: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:4962: error: variable or field `my_jpeg_error'
declared void
BOpcodeHandler.cpp:4962: error: `j_common_ptr' was not declared in this
scope
BOpcodeHandler.cpp:4962: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:4977: error: variable or field `init_destination'
declared void
BOpcodeHandler.cpp:4977: error: `j_compress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:4977: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:4985: error: `boolean' does not name a type
BOpcodeHandler.cpp:5002: error: variable or field `term_destination'
declared void
BOpcodeHandler.cpp:5002: error: `j_compress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:5002: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp: In member function `TK_Status
TK_Image::compress_image(BStreamFileToolkit&)':
BOpcodeHandler.cpp:5022: error: aggregate `jpeg_compress_struct cinfo'
has incomplete type and cannot be defined
BOpcodeHandler.cpp:5023: error: aggregate `jpeg_destination_mgr dest'
BOpcodeHandler.cpp:5025: error: `JSAMPROW' was not declared in this
scope
BOpcodeHandler.cpp:5025: error: expected `;' before "row_pointer"
BOpcodeHandler.cpp:5029: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5029: error: `jpeg_std_error' was not declared in
this scope
BOpcodeHandler.cpp:5031: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5032: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5035: error: `jpeg_destroy_compress' was not declared
in this scope
BOpcodeHandler.cpp:5035: warning: unused variable
'jpeg_destroy_compress'
BOpcodeHandler.cpp:5044: error: `jpeg_create_compress' was not declared
in this scope
BOpcodeHandler.cpp:5048: error: `empty_output_buffer' was not declared
in this scope
BOpcodeHandler.cpp:5055: error: `JCS_RGB' was not declared in this scope
BOpcodeHandler.cpp:5057: error: `jpeg_set_defaults' was not declared in
this scope
BOpcodeHandler.cpp:5058: error: `FALSE' was not declared in this scope
BOpcodeHandler.cpp:5058: error: `jpeg_set_quality' was not declared in
this scope
BOpcodeHandler.cpp:5067: error: `TRUE' was not declared in this scope
BOpcodeHandler.cpp:5067: error: `jpeg_start_compress' was not declared
in this scope
BOpcodeHandler.cpp:5069: error: `row_pointer' was not declared in this
scope
BOpcodeHandler.cpp:5070: error: `jpeg_write_scanlines' was not declared
in this scope
BOpcodeHandler.cpp:5070: warning: unused variable 'jpeg_write_scanlines'
BOpcodeHandler.cpp:5075: error: `jpeg_finish_compress' was not declared
in this scope
BOpcodeHandler.cpp:5077: error: `jpeg_destroy_compress' was not declared
in this scope
BOpcodeHandler.cpp:5029: warning: unused variable 'jpeg_std_error'
BOpcodeHandler.cpp:5044: warning: unused variable 'jpeg_create_compress'
BOpcodeHandler.cpp:5048: warning: unused variable 'empty_output_buffer'
BOpcodeHandler.cpp:5055: warning: unused variable 'JCS_RGB'
BOpcodeHandler.cpp:5057: warning: unused variable 'jpeg_set_defaults'
BOpcodeHandler.cpp:5058: warning: unused variable 'FALSE'
BOpcodeHandler.cpp:5058: warning: unused variable 'jpeg_set_quality'
BOpcodeHandler.cpp:5067: warning: unused variable 'TRUE'
BOpcodeHandler.cpp:5067: warning: unused variable 'jpeg_start_compress'
BOpcodeHandler.cpp:5075: warning: unused variable 'jpeg_finish_compress'
BOpcodeHandler.cpp:5077: warning: unused variable
BOpcodeHandler.cpp: At global scope:
BOpcodeHandler.cpp:5171: error: variable or field `init_source' declared
void
BOpcodeHandler.cpp:5171: error: `j_decompress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:5171: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:5179: error: `boolean' does not name a type
BOpcodeHandler.cpp:5185: error: variable or field `skip_input_data'
declared void
BOpcodeHandler.cpp:5185: error: `j_decompress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:5185: error: expected primary-expression before
"long"
BOpcodeHandler.cpp:5185: error: initializer expression list treated as
compound expression
BOpcodeHandler.cpp:5185: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:5201: error: variable or field `term_source' declared
void
BOpcodeHandler.cpp:5201: error: `j_decompress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:5201: error: expected `,' or `;' before '{' token
TK_Image::decompress_image(BStreamFileToolkit&)':
BOpcodeHandler.cpp:5254: error: aggregate `jpeg_decompress_struct cinfo'
BOpcodeHandler.cpp:5255: error: aggregate `jpeg_source_mgr src' has
BOpcodeHandler.cpp:5257: error: `JSAMPROW' was not declared in this
scope
BOpcodeHandler.cpp:5257: error: expected `;' before "row_pointer"
BOpcodeHandler.cpp:5260: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5260: error: `jpeg_std_error' was not declared in
this scope
BOpcodeHandler.cpp:5262: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5263: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5266: error: `jpeg_destroy_decompress' was not
BOpcodeHandler.cpp:5266: warning: unused variable
'jpeg_destroy_decompress'
BOpcodeHandler.cpp:5270: error: `jpeg_create_decompress' was not
BOpcodeHandler.cpp:5274: error: `fill_input_buffer' was not declared in
this scope
BOpcodeHandler.cpp:5276: error: `jpeg_resync_to_restart' was not
BOpcodeHandler.cpp:5283: error: `TRUE' was not declared in this scope
BOpcodeHandler.cpp:5283: error: `jpeg_read_header' was not declared in
this scope
BOpcodeHandler.cpp:5285: error: `jpeg_start_decompress' was not declared
in this scope
BOpcodeHandler.cpp:5287: error: `row_pointer' was not declared in this
scope
BOpcodeHandler.cpp:5288: error: `jpeg_read_scanlines' was not declared
in this scope
BOpcodeHandler.cpp:5288: warning: unused variable 'jpeg_read_scanlines'
BOpcodeHandler.cpp:5290: error: `jpeg_finish_decompress' was not
BOpcodeHandler.cpp:5292: error: `jpeg_destroy_decompress' was not
BOpcodeHandler.cpp:5257: warning: unused variable 'JSAMPROW'
BOpcodeHandler.cpp:5260: warning: unused variable 'jpeg_std_error'
BOpcodeHandler.cpp:5270: warning: unused variable
'jpeg_create_decompress'
BOpcodeHandler.cpp:5274: warning: unused variable 'fill_input_buffer'
BOpcodeHandler.cpp:5276: warning: unused variable
'jpeg_resync_to_restart'
BOpcodeHandler.cpp:5283: warning: unused variable 'TRUE'
BOpcodeHandler.cpp:5283: warning: unused variable 'jpeg_read_header'
BOpcodeHandler.cpp:5285: warning: unused variable
'jpeg_start_decompress'
BOpcodeHandler.cpp:5290: warning: unused variable
'jpeg_finish_decompress'
BOpcodeHandler.cpp:5292: warning: unused variable
TK_Image::read_jpeg_header()':
BOpcodeHandler.cpp:5357: error: aggregate `jpeg_decompress_struct cinfo'
BOpcodeHandler.cpp:5358: error: aggregate `jpeg_source_mgr src' has
BOpcodeHandler.cpp:5361: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5361: error: `jpeg_std_error' was not declared in
this scope
BOpcodeHandler.cpp:5362: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5363: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5366: error: `jpeg_destroy_decompress' was not
BOpcodeHandler.cpp:5366: warning: unused variable
BOpcodeHandler.cpp:5370: error: `jpeg_create_decompress' was not
BOpcodeHandler.cpp:5373: error: `fill_input_buffer' was not declared in
this scope
BOpcodeHandler.cpp:5375: error: `jpeg_resync_to_restart' was not
BOpcodeHandler.cpp:5382: error: `TRUE' was not declared in this scope
BOpcodeHandler.cpp:5382: error: `jpeg_read_header' was not declared in
this scope
BOpcodeHandler.cpp:5389: error: `jpeg_destroy_decompress' was not
BOpcodeHandler.cpp:5361: warning: unused variable 'jpeg_std_error'
BOpcodeHandler.cpp:5370: warning: unused variable
BOpcodeHandler.cpp:5373: warning: unused variable 'fill_input_buffer'
BOpcodeHandler.cpp:5375: warning: unused variable
BOpcodeHandler.cpp:5382: warning: unused variable 'TRUE'
BOpcodeHandler.cpp:5382: warning: unused variable 'jpeg_read_header'
BOpcodeHandler.cpp:5389: warning: unused variable
make[8]: *** [BOpcodeHandler.lo] Error 1
/dwf/w3dtk'
make[7]: *** [install-recursive] Error 1
/dwf/w3dtk'
make[6]: *** [install-recursive] Error 1
make[6]: Leaving directory
/dwf'
make[5]: *** [install-recursive] Error 1
make[5]: Leaving directory
make[4]: *** [install-recursive] Error 1
make[4]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Oem/DWFTK7.1/develop/global'
make[3]: *** [install-recursive] Error 1
make[3]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Oem/DWFTK7.1/develop'
make[2]: *** [install-recursive] Error 1
make[2]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Oem/DWFTK7.1'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/home/download/mapserver/mapguide-1.0.0/Oem'
make: *** [install-recursive] Error 1
Met vriendelijk groet,
Bas van Dikkenberg
GISkit bv
BFVD1-RIPE
Tel:                  +3130-6340430
Fax:                 +3130-6342433
Prive Tel:          +3130-6372769
Mob:                +316-52384841
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060321/72427530/attachment.html
More information about the Mapguide-users mailing list
