[mapguide-users] Session timeout in viewer samples
Joel Carranza
jec at gatekeeper.com
Wed Mar 22 18:10:46 EST 2006
I am having this problem as well. Seems like the only solution will be to
have a periodic refresh of the map?
Note that you can change Session timeout and Session timer parameters in
administration pages
http://localhost/mapguide/mapadmin/servicesproperties.php
Not sure what the difference between the two is, but you could increase
them. May has an adverse effect on performance though.
--Joel
_____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Wednesday, March 22, 2006 2:29 PM
Subject: RE: [mapguide-users] Session timeout in viewer samples
Yeah.I'm seeing that with the app I'm creating now. Error states that the
Session has expired or is invalid.
Will turning off the password protection solve this problem?
- Juan
_____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, March 22, 2006 5:18 PM
Subject: [mapguide-users] Session timeout in viewer samples
I understand that the viewer samples initiate a session when they are
initially loaded using hardcoded values. This works fine, but if you leave
the map alone for too long (the DWF version anyway) it times out with an
error message, and the only way to get it back appears to be to refresh the
browser.
I can see this being an issue with our front counter PCs which typically
have MapGuide loaded in a browser window all the time, but that window might
not be used for hours at a time.
Any ideas on how to deal with this?
Jason
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060322/a9e6e51e/attachment.html
More information about the Mapguide-users
