[mapguide-users] Session timeout in viewer samples
Jason Birch Jason.Birch at nanaimo.ca
Wed Mar 22 18:27:13 EST 2006
I was thinking that this might be accomplished with a hidden frame and a
meta refresh, but that's a pretty ugly hack
Jason
Sent: Wednesday, March 22, 2006 15:11
Subject: RE: [mapguide-users] Session timeout in viewer samples
I am having this problem as well. Seems like the only solution will be
to have a periodic refresh of the map?
Note that you can change Session timeout and Session timer parameters in
administration pages
http://localhost/mapguide/mapadmin/servicesproperties.php
Not sure what the difference between the two is, but you could increase
them. May has an adverse effect on performance though.
--Joel
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Wednesday, March 22, 2006 2:29 PM
Yeah...I'm seeing that with the app I'm creating now.  Error states that
the Session has expired or is invalid.
Will turning off the password protection solve this problem?
- Juan
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, March 22, 2006 5:18 PM
Subject: [mapguide-users] Session timeout in viewer samples
I understand that the viewer samples initiate a session when they are
initially loaded using hardcoded values.  This works fine, but if you
leave the map alone for too long (the DWF version anyway) it times out
with an error message, and the only way to get it back appears to be to
refresh the browser.
I can see this being an issue with our front counter PCs which typically
have MapGuide loaded in a browser window all the time, but that window
might not be used for hours at a time.
Any ideas on how to deal with this?
Jason
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060322/8a4cdd6f/attachment.html
More information about the Mapguide-users mailing list
