[mapguide-users] SDF load problems
Andy Morsell amorsell at spatialgis.com
Wed Mar 22 20:16:57 EST 2006
Yes, I have done exactly that in the past to see where my files were copied
to in the repository.  I guess my big problem is that there is no way around
copying our data from the place where it is maintained to the repository in
order for it to be accessible as a resource.  Allowing a resource to point
to a different physical location would make data management quite a bit
easier for us and we wouldn't have to worry about reversing out the actual
physical path to that resource and then incorporating that into our batch
routines.  This would also totally eliminate the need to load these
resources at all via HTTP or as packages.
Andy
  _____
From: Edward Zimmerman [mailto:edward.zimmerman at autodesk.com]
Sent: Wednesday, March 22, 2006 4:07 PM
Subject: RE: [mapguide-users] SDF load problems
Regarding "This would be OK if there was an easy way to know where in the
repository that feature source is created when it is initially defined.", do
this experiment:
1)       Name your source data something unique (ex: myUniqueFile.sdf)
2)       Load it using Studio.
3)       On the server, recursively search the Repository folder under the
server installation for the data file (ex: myUniqueFile.sdf).
As long as you don't change the feature source wrapping the data file, the
location of the resource data file on the server won't change. You can
directly update the data file there on the server in the future.
(DISCLAIMER: This hack bypasses the API. If the resource repository
implementation changes, this might break the hack. Be warned. )
Also, to get a feel for the repository API, try using the html forms from in
your browser (http://<server_name>/mapguide/mapagent/index.html). It's an
easy way get a look into the resources being created with the Studio load
procedures.
Ed
  _____
From: Andy Morsell [mailto:amorsell at spatialgis.com]
Sent: Wednesday, March 22, 2006 6:43 PM
I haven't tried it.  I'm sure it would work fine, but it seems like an awful
lot of work to take a Shape file and copy it from one network location to
another (the repository)......... And what about those 1 GB Shape files?
It's a lot of package and data shuffling to keep your repository data in
synch with the source data.  I would like to be able to point the repository
location to reference the source data in my chosen network location.  Sort
of like MapGuide 6.5 UDL files, but you could still retain the managed data
aspect.
In the case of converting your source to SDF+, some of us would rather use
FME scripts to update the SDF files in the repository.  This would be OK if
there was an easy way to know where in the repository that feature source is
Andy
  _____
Sent: Wednesday, March 22, 2006 3:29 PM
Regarding "Many of us will want to update our data through external
processes", has anyone tried to write some code which does the following?
1)       Use the Studio Load API to create the package locally from the
latest source data.
2)       Copy the resulting package file into the Package directory on the
server.
3)       Use the MGOS Admin service API to apply this updated package.
Would this meet most of your needs to update the source flat file data
wrapped by FeatureSource resources?
Thanks,
Ed
  _____
Sent: Wednesday, March 22, 2006 6:03 PM
Sorry, I should have clarified that my rant pertains to flat files only.
Database connections will be direct to their source.
Andy
  _____
From: Butler, Juan P [mailto:jpbutler at co.pinellas.fl.us]
Sent: Wednesday, March 22, 2006 2:46 PM
Wow.  So you're saying that if and when a provider for Oracle Spatial comes
along, we won't be able to define the connection to the database and have
the data come directly from that connection?   It basically dumps the data
(that point in time) into a repository that resides in on the MG server?
Can someone from Autodesk comment on this?
Juan Butler - Senior Programmer/Analyst
GIS Applications
Pinellas County Information Systems
jpbutler at pinellascounty.org
  _____
Sent: Wednesday, March 22, 2006 5:37 PM
This is where using a managed data structure is a detriment, in my opinion.
Many of us will want to update our data through external processes and there
is no easy way to just copy files into the repository or point to an
existing network location.  I think this is going to become a much bigger
problem as people put these systems into production and realize that they
have to "load" their data into repositories.  It's also going to be a large
problem for keeping data up to date with ongoing system maintenance.
Scheduled process are going to be a necessity to ensure that the data in the
repository is in synch with the source data.  And, in the case of large
source datasets, the entire dataset will have to be reloaded as there is no
incremental update method.
I believe (but have not yet done this) that the Studio API is going to have
to be used to load these resources, not the server API.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
Sent: Wednesday, March 22, 2006 2:17 PM
Ahhh. I see, I misunderstood the use of "Packages" and didn't think too look
there.   Thank you. It is working fine now.
I have noticed that imported SDFs are processed (into SDF v3, I believe). Is
it currently possible to import SDF data sources into the repository without
using Studio at all, just using the server API? Is it possible to create
your own Packages using the server API?  I would be interested in doing this
for our migration tools.
Joel Carranza
Gatekeeper Systems
626-449-3070 x114
  _____
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Wednesday, March 22, 2006 1:42 PM
It looks like it's too big.  You'll probably have to "Package" the data and
upload it to the server manually, then bring it in via the site Admin web
app.
Jason
  _____
Sent: Wednesday, March 22, 2006 13:39
Subject: [mapguide-users] SDF load problems
I am trying to load a 225 MB SDF file using MapGuide studio. I have tried
any number of different options and they all seem to fail. The process
crunches for a while, and then says "Communicating with server" and the
progress bars fills to 100% .  Eventually, an error dialog is popped that
says "Unable to complete request to site. Connection lost".
The apache logs showed the following. None of the other logs reported
anything of interest that I could see.
[Wed Mar 22 13:33:54 2006] [warn] FastCGI: (dynamic) server "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/www/mapagent/MapAgent.exe"
restarted (pid 5284)
[Wed Mar 22 13:34:00 2006] [warn] FastCGI: scheduled the restart of the last
process: reached dynamicMaxClassProcs (10)
[Wed Mar 22 13:34:00 2006] [warn] FastCGI: (dynamic) server "C:/Program
restarted (pid 6008)
[Wed Mar 22 13:34:21 2006] [warn] FastCGI: (dynamic) server "C:/Program
Files/MapGuideOpenSource/WebServerExtensions/www/mapagent/MapAgent.exe" (pid
5540) terminated with exit with status '0'
[Wed Mar 22 13:34:38 2006] [warn] FastCGI: (dynamic) server "C:/Program
6008) termination signaled
[Wed Mar 22 13:34:39 2006] [warn] FastCGI: (dynamic) server "C:/Program
6008) terminated with exit with status '0'
Anyone have any ideas about what is going on?
Joel Carranza
Gatekeeper Systems
626-449-3070 x114
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060322/b4b70588/attachment.html
More information about the Mapguide-users mailing list
