[mapguide-users] SDF Question
Randy Glen Johnson
rjohnson at maintenanceconnection.com
Thu Mar 23 16:28:10 EST 2006
I take that back. I am getting the single value "FeatID" but nothing else.
there were at least 6 columns in the dbf file .
Best Regards,
Randy Glen Johnson
Programmer Analyst
Maintenance Connection, Inc.
1-888-567-3434 ext 800
http://www.maintenanceconnection.com <http://www.maintenanceconnection.com/>
-----Original Message-----
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thursday, March 23, 2006 1:17 PM
Subject: RE: [mapguide-users] SDF Question
SDF is the MapGuide proprietary spatial data format.
If you choose to convert SHP to SDF, both the SHP and DBF will be combined
into the resulting SDF file. In general, the data is the same, but you can
expect better performance with SDF. So far there is no simple tool that lets
you view the data in the same way that Excel allows you to view DBF files
for example.
Traian
_____
From: Randy Glen Johnson [mailto:rjohnson at maintenanceconnection.com]
Sent: Thursday, March 23, 2006 4:06 PM
Subject: [mapguide-users] SDF Question
I have some questions regarding SDF files.
My source data is .SHP files with dbf data files
Using Autodesk's MapGuide Studio Preview, I loaded my shape files. It
appears that sdf files were created from wither the shape files or the dbf
files. I am not sure which it used since I cant see the data. Somewhere I
found an option to create a sdf file but I am not familiar with sdf files.
What tool do I use to look at data in a sdf file? Looking on the web only
indicated that sql-ce uses that datatype. I don't have sql-ce. any
information and suggestions would be greatly appreciated.
Best Regards,
Randy Glen Johnson
Programmer Analyst
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060323/b625e1a6/attachment.html
More information about the Mapguide-users
