[mapguide-users] SDF Question
Traian Stanev traian.stanev at autodesk.com
Thu Mar 23 16:36:44 EST 2006
That's weird, it sounds almost like it didn't find or didn't like the
DBF file. Is your DBF file named the same (including case) as your SHP
file and is it in the same directory as the SHP file?
  _____
From: Randy Glen Johnson [mailto:rjohnson at maintenanceconnection.com]
Sent: Thursday, March 23, 2006 4:33 PM
Subject: RE: [mapguide-users] SDF Question
There is only the single item to select from...  the other fields are
not there...
Best Regards,
Randy Glen Johnson
Programmer Analyst
Maintenance Connection, Inc.
1-888-567-3434 ext 800
http://www.maintenanceconnection.com
<http://www.maintenanceconnection.com/>
-----Original Message-----
From: Traian Stanev [mailto:traian.stanev at autodesk.com]
Sent: Thursday, March 23, 2006 1:32 PM
In Studio, in the Layer Editor where the properties are listed, you need
to check the checkboxes for the ones you want displayed on selection.
Traian
  _____
Sent: Thursday, March 23, 2006 4:28 PM
I take that back... I am getting the single value "FeatID" but nothing
else...  there were at least 6 columns in the dbf file ...
Best Regards,
Randy Glen Johnson
Programmer Analyst
Sent: Thursday, March 23, 2006 1:17 PM
SDF is the MapGuide proprietary spatial data format.
If you choose to convert SHP to SDF, both the SHP and DBF will be
combined into the resulting SDF file. In general, the data is the same,
but you can expect better performance with SDF. So far there is no
simple tool that lets you view the data in the same way that Excel
allows you to view DBF files for example.
Traian
  _____
Sent: Thursday, March 23, 2006 4:06 PM
Subject: [mapguide-users] SDF Question
I have some questions regarding SDF files...
My source data is .SHP files with dbf data files
Using Autodesk's MapGuide Studio Preview, I loaded my shape files.  It
appears that sdf files were created from wither the shape files or the
dbf files.  I am not sure which it used since I cant see the data.
Somewhere I found an option to create a sdf file but I am not familiar
with sdf files.  What tool do I use to look at data in a sdf file?
Looking on the web only indicated that sql-ce uses that datatype...  I
don't have sql-ce...  any information and suggestions would be greatly
appreciated.
Best Regards,
Randy Glen Johnson
Programmer Analyst
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060323/f84155f9/attachment.html
More information about the Mapguide-users mailing list
