A simple .Net sample
Steven J Reed
sjreed at edcomputing.com
Fri Mar 24 20:13:19 EST 2006
Would it be too much to ask for a simple .Net sample, say something where
the code was all in one place? The current ajaxviewersample and
dwfviewersample are really just shells that include code from other
directories, then when you look at them they include still more code. It is
difficult to determine what is really needed!
While I'm asking, why aren't the .Net samples in the form of .Net projects?
If you really want .Net programmers to use this put it in the form they are
used to seeing, which is not something that has to be put in a Program
Files\MapGuideOpenSource\WebServerExtensions\www directory!
And of course these samples should have much of the initialization code in
the code-behind module, not embedded in the html code.
Enough bitching, but it really looks like the .Net implementation is an
afterthought!
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060324/8b7dda99/attachment.html
More information about the Mapguide-users
