[mapguide-users] make errors building web exstentions
Traian Stanev traian.stanev at autodesk.com
Tue Mar 28 13:52:04 EST 2006
You could define the CXX and CC environment variables to point to the
correct gcc before running the build. Or you could probably just alias
g++ to g++4, but I'm not positive about that.
Traian
  _____
From: Bas van den Dikkenberg [mailto:bas at giskit.nl]
Sent: Tuesday, March 28, 2006 1:38 PM
Subject: RE: [mapguide-users] make errors building web exstentions
Gcc 4 is also installed but fort hat i need to use the gcc4 comamnd and
not gcc how do tell de build script to gcc4
  _____
Van: Walt Welton-Lair [mailto:walt.welton-lair at autodesk.com]
Verzonden: donderdag 23 maart 2006 16:58
Aan: users at mapguide.osgeo.org
Onderwerp: RE: [mapguide-users] make errors building web exstentions
It looks like errors due to templates.  You're not the first one
encountering this:
http://gcc.gnu.org/ml/gcc-help/2004-12/msg00077.html
http://gcc.gnu.org/ml/gcc-help/2004-11/msg00093.html
At this point I can only recommend upgrading your gcc / g++ to version
4.0.2.
Walt
  _____
Sent: Wednesday, March 22, 2006 4:23 PM
Linux redhat2 2.6.9-34.EL #1 Fri Feb 24 16:44:51 EST 2006 i686 i686 i386
GNU/Linux
gcc (GCC) 3.4.5 20051201 (Red Hat 3.4.5-2)
Copyright (C) 2004 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is
NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
PURPOSE.
Met vriendelijk groet,
Bas van Dikkenberg
GISkit bv
BFVD1-RIPE
Tel:                  +3130-6340430
Fax:                 +3130-6342433
Prive Tel:          +3130-6372769
Mob:                +316-52384841
  _____
Verzonden: woensdag 22 maart 2006 16:24
What kernel / flavor of Linux are you building on?
What version of g++ are you using?
It's always good to include this info when reporting build errors...
  _____
Sent: Wednesday, March 22, 2006 2:01 AM
Jpeg problem solved the devel pakage was not installed but now i'm
getting te following error output:
mv -f CoordSysOutOfMemoryException.o
.libs/CoordSysOutOfMemoryException.lo
g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
-DPACKAGE_VERSION=\"1.0.0\" "-DPACKAGE_STRING=\"mapguide 1.0.0\""
-DPACKAGE_BUGREPORT=\"http://www.mapguide.osgeo.org\"
-DPACKAGE=\"mapguide\" -DVERSION=\"1.0.0\" -DSTDC_HEADERS=1
-DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
-DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
-DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_DLFCN_H=1
-DSTDC_HEADERS=1 -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1 -DHAVE_NETDB_H=1
-DHAVE_NETINET_IN_H=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_SOCKET_H=1
-DHAVE_GETHOSTBYNAME=1 -DHAVE_SOCKET=1 -DHAVE_HTONS=1 -DHAVE_CONNECT=1
-DHAVE_SHUTDOWN=1 -I. -I. -I../../Oem/gdal-1.3.0/ogr
-I../../Oem/gdal-1.3.0/port -I../../Oem/proj-4.4.9/src -g -D_DEBUG -c
CoordSysOutOfMemoryException.cpp -MT CoordSysOutOfMemoryException.lo -MD
-MP -MF .deps/CoordSysOutOfMemoryException.TPlo >/dev/null 2>&1
mv -f .libs/CoordSysOutOfMemoryException.lo
source='CoordSysTransform.cpp' object='CoordSysTransform.lo' libtool=yes
depfile='.deps/CoordSysTransform.Plo'
tmpdepfile='.deps/CoordSysTransform.TPlo' \
depmode=gcc3 /bin/sh ../../depcomp \
/bin/sh ../../libtool --mode=compile g++ -DPACKAGE_NAME=\"mapguide\"
-DPACKAGE_TARNAME=\"mapguide\" -DPACKAGE_VERSION=\"1.0.0\"
-DPACKAGE_STRING=\"mapguide\ 1.0.0\"
-o CoordSysTransform.lo `test -f 'CoordSysTransform.cpp' || echo
'./'`CoordSysTransform.cpp
rm -f .libs/CoordSysTransform.lo
CoordSysTransform.cpp -MT CoordSysTransform.lo -MD -MP -MF
.deps/CoordSysTransform.TPlo  -fPIC -DPIC
In file included from ../../Oem/gdal-1.3.0/port/cpl_port.h:160,
                 from ../../Oem/gdal-1.3.0/ogr/ogr_core.h:117,
                 from ../../Oem/gdal-1.3.0/ogr/ogr_srs_api.h:193,
                 from ../../Oem/gdal-1.3.0/ogr/ogr_spatialref.h:99,
                 from CoordSysIncludes.h:21,
                 from CoordSysTransform.cpp:19:
../../Oem/gdal-1.3.0/port/cpl_config.h:105:1: warning:
"PACKAGE_BUGREPORT" redefined
<command line>:6:1: warning: this is the location of the previous
definition
../../Oem/gdal-1.3.0/port/cpl_config.h:108:1: warning: "PACKAGE_NAME"
redefined
<command line>:2:1: warning: this is the location of the previous
definition
../../Oem/gdal-1.3.0/port/cpl_config.h:111:1: warning: "PACKAGE_STRING"
redefined
<command line>:5:1: warning: this is the location of the previous
definition
../../Oem/gdal-1.3.0/port/cpl_config.h:114:1: warning: "PACKAGE_TARNAME"
redefined
<command line>:3:1: warning: this is the location of the previous
definition
../../Oem/gdal-1.3.0/port/cpl_config.h:117:1: warning: "PACKAGE_VERSION"
redefined
<command line>:4:1: warning: this is the location of the previous
definition
mv -f CoordSysTransform.o .libs/CoordSysTransform.lo
.deps/CoordSysTransform.TPlo >/dev/null 2>&1
mv -f .libs/CoordSysTransform.lo CoordSysTransform.lo
source='CoordSysTransformation.cpp' object='CoordSysTransformation.lo'
libtool=yes \
depfile='.deps/CoordSysTransformation.Plo'
tmpdepfile='.deps/CoordSysTransformation.TPlo' \
-o CoordSysTransformation.lo `test -f 'CoordSysTransformation.cpp' ||
echo './'`CoordSysTransformation.cpp
rm -f .libs/CoordSysTransformation.lo
CoordSysTransformation.cpp -MT CoordSysTransformation.lo -MD -MP -MF
.deps/CoordSysTransformation.TPlo  -fPIC -DPIC
                 from CoordSysTransformation.cpp:19:
definition
redefined
definition
redefined
definition
redefined
definition
redefined
definition
mv -f CoordSysTransformation.o .libs/CoordSysTransformation.lo
.deps/CoordSysTransformation.TPlo >/dev/null 2>&1
mv -f .libs/CoordSysTransformation.lo CoordSysTransformation.lo
source='CoordSysTransformFailedException.cpp'
object='CoordSysTransformFailedException.lo' libtool=yes \
depfile='.deps/CoordSysTransformFailedException.Plo'
tmpdepfile='.deps/CoordSysTransformFailedException.TPlo' \
-o CoordSysTransformFailedException.lo `test -f
'CoordSysTransformFailedException.cpp' || echo
'./'`CoordSysTransformFailedException.cpp
rm -f .libs/CoordSysTransformFailedException.lo
CoordSysTransformFailedException.cpp -MT
CoordSysTransformFailedException.lo -MD -MP -MF
.deps/CoordSysTransformFailedException.TPlo  -fPIC -DPIC
                 from CoordSysTransformFailedException.cpp:19:
definition
redefined
definition
redefined
definition
redefined
definition
redefined
definition
mv -f CoordSysTransformFailedException.o
.deps/CoordSysTransformFailedException.TPlo >/dev/null 2>&1
mv -f .libs/CoordSysTransformFailedException.lo
/bin/sh ../../libtool --mode=link g++  -g -D_DEBUG   -o
libMgCoordinateSystem.la -rpath /usr/local/mapguideopensource/lib
-version-info 7:0:0 -L../../Oem/gdal-1.3.0 -L../../Oem/proj-4.4.9/src
CoordSys.lo CoordSysCatalog.lo CoordSysCategory.lo
CoordSysCategoryCollection.lo CoordSysComputationFailedException.lo
CoordSysConversionFailedException.lo CoordSysEnvelope.lo
CoordSysException.lo CoordSysFactory.lo CoordSysInformation.lo
CoordSysInitializationFailedException.lo
CoordSysInvalidArgumentException.lo
CoordSysInvalidCoordinateSystemException.lo
CoordSysInvalidCoordinateSystemTypeException.lo
CoordSysInvalidCoordinateSystemUnitsException.lo CoordSysMeasure.lo
CoordSysMeasureFailedException.lo CoordSysNullArgumentException.lo
CoordSysNullReferenceException.lo CoordSysOutOfMemoryException.lo
CoordSysTransform.lo CoordSysTransformation.lo
CoordSysTransformFailedException.lo -lgdal -lproj
rm -fr .libs/libMgCoordinateSystem.la .libs/libMgCoordinateSystem.*
gcc -shared  CoordSys.lo CoordSysCatalog.lo CoordSysCategory.lo
CoordSysTransformFailedException.lo  -Wl,--rpath
-Wl,/home/download/mapserver/mapguide-1.0.0/Oem/gdal-1.3.0/.libs
-Wl,--rpath
-Wl,/home/download/mapserver/mapguide-1.0.0/Oem/proj-4.4.9/src/.libs
-Wl,--rpath -Wl,/usr/local/mapguideopensource/lib  -L/usr/lib/mysql
-L/usr/lib -L/usr/local/lib
-L/home/download/mapserver/mapguide-1.0.0/Oem/gdal-1.3.0
-L/home/download/mapserver/mapguide-1.0.0/Oem/proj-4.4.9/src
/home/download/mapserver/mapguide-1.0.0/Oem/gdal-1.3.0/.libs/libgdal.so
/home/download/mapserver/mapguide-1.0.0/Oem/proj-4.4.9/src/.libs/libproj
.so    -Wl,-soname -Wl,libMgCoordinateSystem.so.7 -o
.libs/libMgCoordinateSystem.so.7.0.0
(cd .libs && rm -f libMgCoordinateSystem.so.7 && ln -s
libMgCoordinateSystem.so.7.0.0 libMgCoordinateSystem.so.7)
(cd .libs && rm -f libMgCoordinateSystem.so && ln -s
libMgCoordinateSystem.so.7.0.0 libMgCoordinateSystem.so)
ar cru .libs/libMgCoordinateSystem.a  CoordSys.o CoordSysCatalog.o
CoordSysCategory.o CoordSysCategoryCollection.o
CoordSysComputationFailedException.o CoordSysConversionFailedException.o
CoordSysEnvelope.o CoordSysException.o CoordSysFactory.o
CoordSysInformation.o CoordSysInitializationFailedException.o
CoordSysInvalidArgumentException.o
CoordSysInvalidCoordinateSystemException.o
CoordSysInvalidCoordinateSystemTypeException.o
CoordSysInvalidCoordinateSystemUnitsException.o CoordSysMeasure.o
CoordSysMeasureFailedException.o CoordSysNullArgumentException.o
CoordSysNullReferenceException.o CoordSysOutOfMemoryException.o
CoordSysTransform.o CoordSysTransformation.o
ranlib .libs/libMgCoordinateSystem.a
creating libMgCoordinateSystem.la
(cd .libs && rm -f libMgCoordinateSystem.la && ln -s
../libMgCoordinateSystem.la libMgCoordinateSystem.la)
make[2]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Common/CoordinateSystem'
Making all in MdfModel
make[2]: Entering directory
`/home/download/mapserver/mapguide-1.0.0/Common/MdfModel'
make[2]: Nothing to be done for `all'.
Making all in MdfParser
`/home/download/mapserver/mapguide-1.0.0/Common/MdfParser'
Making all in Security
`/home/download/mapserver/mapguide-1.0.0/Common/Security'
Making all in Service
`/home/download/mapserver/mapguide-1.0.0/Common/Service'
source='Controller/ServiceControllerBuild.cpp'
object='ServiceControllerBuild.lo' libtool=yes \
depfile='.deps/ServiceControllerBuild.Plo'
tmpdepfile='.deps/ServiceControllerBuild.TPlo' \
-DHAVE_SHUTDOWN=1  -I. -I. -IController -ICoordinateSystem -IData
-IException -IGeometry -IMapLayer -INet -IServices -ISystem -IUtil
-I../Security -I../MdfParser -I../MdfModel -I../../Oem/ACE/ACE_wrappers
-I../../Oem/geos-2.2.0/source/headers
-I../../Oem/dbxml-2.2.13/xerces-c-src/src -I../../Oem/proj-4.4.9/src
-I../../Oem/gdal-1.3.0/ogr -I../../Oem/gdal-1.3.0/port
-I../../Common/CoordinateSystem    -g -D_DEBUG -c -o
ServiceControllerBuild.lo `test -f
'Controller/ServiceControllerBuild.cpp' || echo
'./'`Controller/ServiceControllerBuild.cpp
rm -f .libs/ServiceControllerBuild.lo
Controller/ServiceControllerBuild.cpp -MT ServiceControllerBuild.lo -MD
-MP -MF .deps/ServiceControllerBuild.TPlo  -fPIC -DPIC
../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.h:940,
                 from ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:18,
                 from ../../Oem/ACE/ACE_wrappers/ace/Acceptor.h:24,
                 from ./AceCommon.h:56,
                 from Controller/Controller.cpp:18,
                 from Controller/ServiceControllerBuild.cpp:18:
../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp: In member
function `int ACE_Hash_Map_Manager_Ex<EXT_ID, INT_ID, HASH_KEY,
COMPARE_KEYS, ACE_LOCK>::close_i()':
../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:158: error:
expected class-name before '(' token
COMPARE_KEYS, ACE_LOCK>::unbind_all_i()':
../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:190: error:
COMPARE_KEYS, ACE_LOCK>::unbind_i(ACE_Hash_Map_Entry<EXT_ID, INT_ID>*)':
../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:289: error:
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.h:286,
                 from
../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:26,
                 from ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:25,
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In member function
`void ACE_Unbounded_Queue<T>::delete_nodes()':
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:133: error: expected
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In destructor
`ACE_Unbounded_Queue<T>::~ACE_Unbounded_Queue()':
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:153: error: expected
`int ACE_Unbounded_Queue<T>::dequeue_head(T&)':
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:223: error: expected
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.h:307,
                 from ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:34,
                 from ../../Oem/ACE/ACE_wrappers/ace/Containers.h:69,
                 from
../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:27,
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In member function
`void ACE_Unbounded_Set<T>::delete_nodes()':
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:107: error: expected
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In destructor
`ACE_Unbounded_Set<T>::~ACE_Unbounded_Set()':
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:126: error: expected
`int ACE_Unbounded_Set<T>::remove(const T&)':
../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:230: error: expected
../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:1986,
                 from
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In member function
`void ACE_Unbounded_Stack<T>::delete_all_nodes()':
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:171: error: expected
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In destructor
`ACE_Unbounded_Stack<T>::~ACE_Unbounded_Stack()':
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:239: error: expected
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In member function `int
ACE_Unbounded_Stack<T>::pop(T&)':
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:275: error: expected
ACE_Unbounded_Stack<T>::remove(const T&)':
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:334: error: expected
ACE_Ordered_MultiSet<T>::remove(const T&)':
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1582: error: expected
`void ACE_Ordered_MultiSet<T>::delete_nodes()':
../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1786: error: expected
make[2]: *** [ServiceControllerBuild.lo] Error 1
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Common'
make: *** [all-recursive] Error 1
  _____
Verzonden: dinsdag 21 maart 2006 23:08
The errors appear to be jpeg-related.  Do you have the jpeg package
installed on your machine?  It's required...
  _____
Sent: Tuesday, March 21, 2006 5:04 PM
Subject: [mapguide-users] make errors building web exstentions
If have run the following command  a cording to manual
./build_oem.sh
Then ./configure --enable-server=no still no errors
When I run make I get following error wat am I doing wrong?
/usr/bin/install -c -m 644 'macro_draw.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/macro_draw.h'
 /usr/bin/install -c -m 644 'macro_scale.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/macro_scale.h'
 /usr/bin/install -c -m 644 'macro_index.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/macro_index.h'
 /usr/bin/install -c -m 644 'marksize.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/marksize.h'
 /usr/bin/install -c -m 644 'marksymb.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/marksymb.h'
 /usr/bin/install -c -m 644 'matrix.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/matrix.h'
 /usr/bin/install -c -m 644 'merge_control.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/merge_control.h'
 /usr/bin/install -c -m 644 'named_view.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/named_view.h'
 /usr/bin/install -c -m 644 'named_view_list.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/named_view_list.h'
 /usr/bin/install -c -m 644 'object.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/object.h'
 /usr/bin/install -c -m 644 'object_node.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/object_node.h'
 /usr/bin/install -c -m 644 'object_node_list.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/object_node_list.h'
 /usr/bin/install -c -m 644 'object_stream.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/object_stream.h'
 /usr/bin/install -c -m 644 'opcode.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/opcode.h'
 /usr/bin/install -c -m 644 'opcode_defs.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/opcode_defs.h'
 /usr/bin/install -c -m 644 'origin.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/origin.h'
 /usr/bin/install -c -m 644 'overpost.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/overpost.h'
 /usr/bin/install -c -m 644 'palette.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/palette.h'
 /usr/bin/install -c -m 644 'pattern_scale.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/pattern_scale.h'
 /usr/bin/install -c -m 644 'pch.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/pch.h'
 /usr/bin/install -c -m 644 'penpat.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/penpat.h'
 /usr/bin/install -c -m 644 'penpat_options.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/penpat_options.h'
 /usr/bin/install -c -m 644 'plot_optimized.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/plot_optimized.h'
 /usr/bin/install -c -m 644 'plotinfo.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/plotinfo.h'
 /usr/bin/install -c -m 644 'pnggroup4image.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/pnggroup4image.h'
 /usr/bin/install -c -m 644 'point.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/point.h'
 /usr/bin/install -c -m 644 'pointset.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/pointset.h'
 /usr/bin/install -c -m 644 'polygon.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/polygon.h'
 /usr/bin/install -c -m 644 'polyline.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/polyline.h'
 /usr/bin/install -c -m 644 'polymark.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/polymark.h'
 /usr/bin/install -c -m 644 'polytri.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/polytri.h'
 /usr/bin/install -c -m 644 'preload.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/preload.h'
 /usr/bin/install -c -m 644 'projection.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/projection.h'
 /usr/bin/install -c -m 644 'rendition.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/rendition.h'
 /usr/bin/install -c -m 644 'rendopts.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/rendopts.h'
 /usr/bin/install -c -m 644 'resource.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/resource.h'
 /usr/bin/install -c -m 644 'rgb.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/rgb.h'
 /usr/bin/install -c -m 644 'signdata.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/signdata.h'
 /usr/bin/install -c -m 644 'text.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text.h'
 /usr/bin/install -c -m 644 'text_background.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text_background.h'
 /usr/bin/install -c -m 644 'text_options.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text_options.h'
 /usr/bin/install -c -m 644 'text_halign.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text_halign.h'
 /usr/bin/install -c -m 644 'text_valign.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/text_valign.h'
 /usr/bin/install -c -m 644 'timestamp.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/timestamp.h'
 /usr/bin/install -c -m 644 'transform.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/transform.h'
 /usr/bin/install -c -m 644 'trusted_font_list.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/trusted_font_list.h'
 /usr/bin/install -c -m 644 'typedefs_defines.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/typedefs_defines.h'
 /usr/bin/install -c -m 644 'units.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/units.h'
 /usr/bin/install -c -m 644 'unknown.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/unknown.h'
 /usr/bin/install -c -m 644 'url.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/url.h'
 /usr/bin/install -c -m 644 'url_list.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/url_list.h'
 /usr/bin/install -c -m 644 'userdata.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/userdata.h'
 /usr/bin/install -c -m 644 'usrfillpat.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/usrfillpat.h'
 /usr/bin/install -c -m 644 'usrhatchpat.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/usrhatchpat.h'
 /usr/bin/install -c -m 644 'view.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/view.h'
 /usr/bin/install -c -m 644 'viewport.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/viewport.h'
 /usr/bin/install -c -m 644 'viewport_options.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/viewport_options.h'
 /usr/bin/install -c -m 644 'visible.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/visible.h'
 /usr/bin/install -c -m 644 'whip_toolkit.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/whip_toolkit.h'
 /usr/bin/install -c -m 644 'whipcore.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/whipcore.h'
 /usr/bin/install -c -m 644 'whiperrs.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/whiperrs.h'
 /usr/bin/install -c -m 644 'wtstring.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/wtstring.h'
 /usr/bin/install -c -m 644 'wversion.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/wversion.h'
 /usr/bin/install -c -m 644 'wendian.h'
'/usr/local/mapguideopensource/include/dwf/whiptk/wendian.h'
make[8]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Oem/DWFTK7.1/develop/global/src
/dwf/whiptk'
make[7]: Leaving directory
/dwf/whiptk'
Making install in w3dtk
make[7]: Entering directory
/dwf/w3dtk'
Making install in jpeg
make[8]: Entering directory
/dwf/w3dtk/jpeg'
make[9]: Entering directory
/dwf/w3dtk/jpeg'
make[9]: Nothing to be done for `install-exec-am'.
test -z "/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg" || mkdir
-p -- "/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg"
 /usr/bin/install -c -m 644 'jchuff.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jchuff.h'
 /usr/bin/install -c -m 644 'jconfig.cfg'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.cfg'
 /usr/bin/install -c -m 644 'jconfig.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.h'
 /usr/bin/install -c -m 644 'jconfig.hpux'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.hpux'
 /usr/bin/install -c -m 644 'jconfig.irix'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.irix'
 /usr/bin/install -c -m 644 'jconfig.solaris'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.solaris'
 /usr/bin/install -c -m 644 'jconfig.vc'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.vc'
 /usr/bin/install -c -m 644 'jconfig.vms'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jconfig.vms'
 /usr/bin/install -c -m 644 'jdct.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jdct.h'
 /usr/bin/install -c -m 644 'jdhuff.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jdhuff.h'
 /usr/bin/install -c -m 644 'jerror.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jerror.h'
 /usr/bin/install -c -m 644 'jinclude.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jinclude.h'
 /usr/bin/install -c -m 644 'jmemsys.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jmemsys.h'
 /usr/bin/install -c -m 644 'jmorecfg.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jmorecfg.h'
 /usr/bin/install -c -m 644 'jpegint.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jpegint.h'
 /usr/bin/install -c -m 644 'jpeglib.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jpeglib.h'
 /usr/bin/install -c -m 644 'jversion.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/jpeg/jversion.h'
make[9]: Leaving directory
/dwf/w3dtk/jpeg'
/dwf/w3dtk/jpeg'
Making install in utility
/dwf/w3dtk/utility'
/dwf/w3dtk/utility'
test -z "/usr/local/mapguideopensource/include/dwf/w3dtk/utility" ||
mkdir -p -- "/usr/local/mapguideopensource/include/dwf/w3dtk/utility"
 /usr/bin/install -c -m 644 'varray.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/varray.h'
 /usr/bin/install -c -m 644 'vconf.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vconf.h'
 /usr/bin/install -c -m 644 'vhash.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vhash.h'
 /usr/bin/install -c -m 644 'vheap.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vheap.h'
 /usr/bin/install -c -m 644 'vlist.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vlist.h'
 /usr/bin/install -c -m 644 'vlogfile.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/utility/vlogfile.h'
/dwf/w3dtk/utility'
/dwf/w3dtk/utility'
Making install in hoops
/dwf/w3dtk/hoops'
/dwf/w3dtk/hoops'
test -z "/usr/local/mapguideopensource/include/dwf/w3dtk/hoops" || mkdir
-p -- "/usr/local/mapguideopensource/include/dwf/w3dtk/hoops"
 /usr/bin/install -c -m 644 'hoops_tools.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/hoops/hoops_tools.h'
 /usr/bin/install -c -m 644 'lod.h'
'/usr/local/mapguideopensource/include/dwf/w3dtk/hoops/lod.h'
/dwf/w3dtk/hoops'
/dwf/w3dtk/hoops'
/dwf/w3dtk'
if /bin/sh ../libtool --mode=compile --tag=CXX g++ -DHAVE_CONFIG_H
-I../..   -DBSTREAM_DISABLE_REPULSE_COMPRESSION  -g0 -O2 -pipe -pedantic
-Wall -Wno-long-long  -Wnon-virtual-dtor -Wsign-promo -Wsign-compare
-Wundef -Wstrict-prototypes -fforce-addr -fomit-frame-pointer
-finline-functions -ffast-math -fno-strict-aliasing -MT
BOpcodeHandler.lo -MD -MP -MF ".deps/BOpcodeHandler.Tpo" -c -o
BOpcodeHandler.lo BOpcodeHandler.cpp; \
then mv -f ".deps/BOpcodeHandler.Tpo" ".deps/BOpcodeHandler.Plo"; else
rm -f ".deps/BOpcodeHandler.Tpo"; exit 1; fi
 g++ -DHAVE_CONFIG_H -I../.. -DBSTREAM_DISABLE_REPULSE_COMPRESSION -g0
-O2 -pipe -pedantic -Wall -Wno-long-long -Wnon-virtual-dtor -Wsign-promo
-Wsign-compare -Wundef -Wstrict-prototypes -fforce-addr
-fomit-frame-pointer -finline-functions -ffast-math -fno-strict-aliasing
-MT BOpcodeHandler.lo -MD -MP -MF .deps/BOpcodeHandler.Tpo -c
BOpcodeHandler.cpp  -fPIC -DPIC -o .libs/BOpcodeHandler.o
cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
Ada/C/ObjC but not for C++
BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or directory
BOpcodeHandler.cpp:4948: error: field `jerr' has incomplete type
BOpcodeHandler.cpp:4954: error: variable or field `my_jpeg_messages'
declared void
BOpcodeHandler.cpp:4954: error: `j_common_ptr' was not declared in this
scope
BOpcodeHandler.cpp:4954: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:4962: error: variable or field `my_jpeg_error'
declared void
BOpcodeHandler.cpp:4962: error: `j_common_ptr' was not declared in this
scope
BOpcodeHandler.cpp:4962: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:4977: error: variable or field `init_destination'
declared void
BOpcodeHandler.cpp:4977: error: `j_compress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:4977: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:4985: error: `boolean' does not name a type
BOpcodeHandler.cpp:5002: error: variable or field `term_destination'
declared void
BOpcodeHandler.cpp:5002: error: `j_compress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:5002: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp: In member function `TK_Status
TK_Image::compress_image(BStreamFileToolkit&)':
BOpcodeHandler.cpp:5022: error: aggregate `jpeg_compress_struct cinfo'
has incomplete type and cannot be defined
BOpcodeHandler.cpp:5023: error: aggregate `jpeg_destination_mgr dest'
BOpcodeHandler.cpp:5025: error: `JSAMPROW' was not declared in this
scope
BOpcodeHandler.cpp:5025: error: expected `;' before "row_pointer"
BOpcodeHandler.cpp:5029: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5029: error: `jpeg_std_error' was not declared in
this scope
BOpcodeHandler.cpp:5031: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5032: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5035: error: `jpeg_destroy_compress' was not declared
in this scope
BOpcodeHandler.cpp:5035: warning: unused variable
'jpeg_destroy_compress'
BOpcodeHandler.cpp:5044: error: `jpeg_create_compress' was not declared
in this scope
BOpcodeHandler.cpp:5048: error: `empty_output_buffer' was not declared
in this scope
BOpcodeHandler.cpp:5055: error: `JCS_RGB' was not declared in this scope
BOpcodeHandler.cpp:5057: error: `jpeg_set_defaults' was not declared in
this scope
BOpcodeHandler.cpp:5058: error: `FALSE' was not declared in this scope
BOpcodeHandler.cpp:5058: error: `jpeg_set_quality' was not declared in
this scope
BOpcodeHandler.cpp:5067: error: `TRUE' was not declared in this scope
BOpcodeHandler.cpp:5067: error: `jpeg_start_compress' was not declared
in this scope
BOpcodeHandler.cpp:5069: error: `row_pointer' was not declared in this
scope
BOpcodeHandler.cpp:5070: error: `jpeg_write_scanlines' was not declared
in this scope
BOpcodeHandler.cpp:5070: warning: unused variable 'jpeg_write_scanlines'
BOpcodeHandler.cpp:5075: error: `jpeg_finish_compress' was not declared
in this scope
BOpcodeHandler.cpp:5077: error: `jpeg_destroy_compress' was not declared
in this scope
BOpcodeHandler.cpp:5029: warning: unused variable 'jpeg_std_error'
BOpcodeHandler.cpp:5044: warning: unused variable 'jpeg_create_compress'
BOpcodeHandler.cpp:5048: warning: unused variable 'empty_output_buffer'
BOpcodeHandler.cpp:5055: warning: unused variable 'JCS_RGB'
BOpcodeHandler.cpp:5057: warning: unused variable 'jpeg_set_defaults'
BOpcodeHandler.cpp:5058: warning: unused variable 'FALSE'
BOpcodeHandler.cpp:5058: warning: unused variable 'jpeg_set_quality'
BOpcodeHandler.cpp:5067: warning: unused variable 'TRUE'
BOpcodeHandler.cpp:5067: warning: unused variable 'jpeg_start_compress'
BOpcodeHandler.cpp:5075: warning: unused variable 'jpeg_finish_compress'
BOpcodeHandler.cpp:5077: warning: unused variable
BOpcodeHandler.cpp: At global scope:
BOpcodeHandler.cpp:5171: error: variable or field `init_source' declared
void
BOpcodeHandler.cpp:5171: error: `j_decompress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:5171: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:5179: error: `boolean' does not name a type
BOpcodeHandler.cpp:5185: error: variable or field `skip_input_data'
declared void
BOpcodeHandler.cpp:5185: error: `j_decompress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:5185: error: expected primary-expression before
"long"
BOpcodeHandler.cpp:5185: error: initializer expression list treated as
compound expression
BOpcodeHandler.cpp:5185: error: expected `,' or `;' before '{' token
BOpcodeHandler.cpp:5201: error: variable or field `term_source' declared
void
BOpcodeHandler.cpp:5201: error: `j_decompress_ptr' was not declared in
this scope
BOpcodeHandler.cpp:5201: error: expected `,' or `;' before '{' token
TK_Image::decompress_image(BStreamFileToolkit&)':
BOpcodeHandler.cpp:5254: error: aggregate `jpeg_decompress_struct cinfo'
BOpcodeHandler.cpp:5255: error: aggregate `jpeg_source_mgr src' has
BOpcodeHandler.cpp:5257: error: `JSAMPROW' was not declared in this
scope
BOpcodeHandler.cpp:5257: error: expected `;' before "row_pointer"
BOpcodeHandler.cpp:5260: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5260: error: `jpeg_std_error' was not declared in
this scope
BOpcodeHandler.cpp:5262: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5263: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5266: error: `jpeg_destroy_decompress' was not
BOpcodeHandler.cpp:5266: warning: unused variable
'jpeg_destroy_decompress'
BOpcodeHandler.cpp:5270: error: `jpeg_create_decompress' was not
BOpcodeHandler.cpp:5274: error: `fill_input_buffer' was not declared in
this scope
BOpcodeHandler.cpp:5276: error: `jpeg_resync_to_restart' was not
BOpcodeHandler.cpp:5283: error: `TRUE' was not declared in this scope
BOpcodeHandler.cpp:5283: error: `jpeg_read_header' was not declared in
this scope
BOpcodeHandler.cpp:5285: error: `jpeg_start_decompress' was not declared
in this scope
BOpcodeHandler.cpp:5287: error: `row_pointer' was not declared in this
scope
BOpcodeHandler.cpp:5288: error: `jpeg_read_scanlines' was not declared
in this scope
BOpcodeHandler.cpp:5288: warning: unused variable 'jpeg_read_scanlines'
BOpcodeHandler.cpp:5290: error: `jpeg_finish_decompress' was not
BOpcodeHandler.cpp:5292: error: `jpeg_destroy_decompress' was not
BOpcodeHandler.cpp:5257: warning: unused variable 'JSAMPROW'
BOpcodeHandler.cpp:5260: warning: unused variable 'jpeg_std_error'
BOpcodeHandler.cpp:5270: warning: unused variable
'jpeg_create_decompress'
BOpcodeHandler.cpp:5274: warning: unused variable 'fill_input_buffer'
BOpcodeHandler.cpp:5276: warning: unused variable
'jpeg_resync_to_restart'
BOpcodeHandler.cpp:5283: warning: unused variable 'TRUE'
BOpcodeHandler.cpp:5283: warning: unused variable 'jpeg_read_header'
BOpcodeHandler.cpp:5285: warning: unused variable
'jpeg_start_decompress'
BOpcodeHandler.cpp:5290: warning: unused variable
'jpeg_finish_decompress'
BOpcodeHandler.cpp:5292: warning: unused variable
TK_Image::read_jpeg_header()':
BOpcodeHandler.cpp:5357: error: aggregate `jpeg_decompress_struct cinfo'
BOpcodeHandler.cpp:5358: error: aggregate `jpeg_source_mgr src' has
BOpcodeHandler.cpp:5361: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5361: error: `jpeg_std_error' was not declared in
this scope
BOpcodeHandler.cpp:5362: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5363: error: 'struct my_error_mgr' has no member
named 'jerr'
BOpcodeHandler.cpp:5366: error: `jpeg_destroy_decompress' was not
BOpcodeHandler.cpp:5366: warning: unused variable
BOpcodeHandler.cpp:5370: error: `jpeg_create_decompress' was not
BOpcodeHandler.cpp:5373: error: `fill_input_buffer' was not declared in
this scope
BOpcodeHandler.cpp:5375: error: `jpeg_resync_to_restart' was not
BOpcodeHandler.cpp:5382: error: `TRUE' was not declared in this scope
BOpcodeHandler.cpp:5382: error: `jpeg_read_header' was not declared in
this scope
BOpcodeHandler.cpp:5389: error: `jpeg_destroy_decompress' was not
BOpcodeHandler.cpp:5361: warning: unused variable 'jpeg_std_error'
BOpcodeHandler.cpp:5370: warning: unused variable
BOpcodeHandler.cpp:5373: warning: unused variable 'fill_input_buffer'
BOpcodeHandler.cpp:5375: warning: unused variable
BOpcodeHandler.cpp:5382: warning: unused variable 'TRUE'
BOpcodeHandler.cpp:5382: warning: unused variable 'jpeg_read_header'
BOpcodeHandler.cpp:5389: warning: unused variable
make[8]: *** [BOpcodeHandler.lo] Error 1
/dwf/w3dtk'
make[7]: *** [install-recursive] Error 1
/dwf/w3dtk'
make[6]: *** [install-recursive] Error 1
make[6]: Leaving directory
/dwf'
make[5]: *** [install-recursive] Error 1
make[5]: Leaving directory
make[4]: *** [install-recursive] Error 1
make[4]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Oem/DWFTK7.1/develop/global'
make[3]: *** [install-recursive] Error 1
make[3]: Leaving directory
`/home/download/mapserver/mapguide-1.0.0/Oem/DWFTK7.1/develop'
make[2]: *** [install-recursive] Error 1
`/home/download/mapserver/mapguide-1.0.0/Oem/DWFTK7.1'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/home/download/mapserver/mapguide-1.0.0/Oem'
make: *** [install-recursive] Error 1
Bas van Dikkenberg
GISkit bv
BFVD1-RIPE
Tel:                  +3130-6340430
Fax:                 +3130-6342433
Mob:                +316-52384841
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060328/35ed10c2/attachment.html
More information about the Mapguide-users mailing list
