[mapguide-users] RE: Newbie Questions
Chris Claydon chris.claydon at autodesk.com
Tue Mar 28 15:17:31 EST 2006
The sample request below contains an unwanted ampersand (&) directly
after the question mark (?). This probably interferes with the detection
of the "REQUEST" parameter.
I tried removing the ampersand (I also had to change
"LAYERS=Zoning_2005" to "LAYERS=Layers/Zoning_2005") and I got back a
valid, but empty image, without being prompted for authentication.
This is the request I made:
http://12.144.53.43/mapguide/mapagent/mapagent.fcgi?REQUEST=GetMap&SERVI
CE=WMS&VERSION=1.1.1&LAYERS=Layers/Zoning_2005&STYLES=default&FORMAT=ima
ge/gif&BGCOLOR=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:4326&BBOX=-74.77294921
875,40.613952441166596,-74.761962890625,40.622291783092706&WIDTH=256&HEI
GHT=256&reaspect=false
Chris.
----- Original Message ----
To: "users at mapguide.osgeo.org" <users at mapguide.osgeo.org>
Sent: Tuesday, March 28, 2006 11:22:03 AM
Subject: [mapguide-users] RE: Newbie Questions
thanks
yea, it does contain both a REQUEST and SERVICE parameter...
I am just typing the request into the browser directly, I should get
back
the image like any other WMS service.
http://12.144.53.43/mapguide/mapagent/mapagent.fcgi?&REQUEST=GetMap&SERV
ICE=
WMS&VERSION=1.1.1&LAYERS=Zoning_2005&STYLES=default&FORMAT=image/gif&BGC
OLOR
=0xFFFFFF&TRANSPARENT=TRUE&SRS=EPSG:4326&BBOX=-74.77294921875,40.6139524
4116
6596,-74.761962890625,40.622291783092706&WIDTH=256&HEIGHT=256&reaspect=f
alse
I've tried it without the "reaspect" parameter as well...
this is from the Error log:
<2006-03-28T14:10:04>     Mozilla/4.0 (compatible; MSIE 6.0; Windows NT
5.2;
SV1; .NET CLR 1.0.3705; .NET CLR 1.1.4322; .NET CLR 2.0.50727)
12.144.53.43
Error: Session has expired or is invalid. Please log in again.
StackTrace:
  - MgOpAuthenticate.Execute line 111 file
c:\build_tux_area\mgdev\server\src\services\site\OpAuthenticate.cpp
  - MgSecurityManager.Authenticate line 227 file
c:\build_tux_area\mgdev\server\src\common\manager\SecurityManager.cpp
  - MgSessionCache.GetSessionInfo line 157 file
c:\build_tux_area\mgdev\server\src\common\manager\SessionCache.cppSessio
n
-----Original Message-----
Sent: Tuesday, March 28, 2006 1:42 PM
To: 'users at mapguide.osgeo.org'
Subject: Newbie Questions
greetings
just digging into mgos so please forgive the simple questions...
got everything working on a Windows 2003 server. Imported data using the
Autodesk Preview program (quite nice). Figured out how to enable WMS
services and I can query the GetCapabilities file successfully.
1) Whenever I try use the mapagent to make a WMS request (other then
GetCapabilities) it requires a logon. I must be missing the simple
setting
to allow anonymous users access to WMS mapping...
2) in the designer, is there an easy way to set the initial extent of a
map
to the full extent of any layer/feature class? There is handy link to
make
the initial extent the current exent of the preview map but nothing that
would set it to the extent of any one layer inside the map. Also, I know
my
data is NAD83 SPC in NJ but it looks like the coords in the extent
bounds
for the data are wrong? any thoughts?
cheers
brian
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060328/df5649b2/attachment.html
More information about the Mapguide-users mailing list
