[mapguide-users] Check if service is running?
Jason Birch Jason.Birch at nanaimo.ca
Tue May 2 02:44:51 EDT 2006
Well, I made some headway on this, but ran into a bug along the way:
https://mapguide.osgeo.org/servlets/Scarab?id=MG269
I could have sworn that I had reported this earlier, but I couldn't find it in the PT.  Basically NET START "MapGuide Server" does not work because of a name conflict with the "Server" service.  Anyone else see this?  The SC command (possibly another XP/2k3-specific command) appears to work because it only accepts the service name.
You can download a draft PHP CLI health monitoring utility here:
http://www.jasonbirch.com/files/mghealthmonitor.zip
Note, this utility is probably XP/Win2k3-specific. Let me know what you think.
Jason
From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
Sent: Mon 2006-05-01 3:02 PM
Subject: RE: [mapguide-users] Check if service is running?
I wish Windows had the same kind of consistent command line tools that unix does.  I'm trying to think of a way to deal with this across Win2k/XP/Win2k3, but short of using the Sysinternals tools I'm drawing a blank.  ps and grep would really come in handy.
- The Windows KILL command doesn't appear to have a mechanism for identifying the process ID beforehand.
- The TASKKILL command appears to have everything we need, but it isn't available in 2000
I think I'm going to take the easy way out and use TASKKILL, with alternate instructions for downloading and using pskill.
Jason
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060501/357beacb/attachment.bin
More information about the Mapguide-users mailing list
