[mapguide-users] Sample application in PHP - HELP
Andy Morsell amorsell at spatialgis.com
Thu May 4 11:18:37 EDT 2006
It sounds to me like you are not using Studio to load your data or create
packages.  Instead, you are reverse engineering the sample package MGP and
it's contained XML files and then editing those XML files directly?  Try
loading some data through Studio, either directly or by creating packages
there and then loading them through Admin, to see if that gets you further.
Andy Morsell, P.E.
Spatial Integrators, Inc.
http://www.SpatialGIS.com
  _____
From: Dimitrios Fryganiotis [mailto:dimitrios.fryganiotis at nsl.eu.com]
Sent: Thursday, May 04, 2006 8:11 AM
Subject: [mapguide-users] Sample application in PHP - HELP
Hello,
  I am trying to create a very simple application in PHP which basically is
going to
plot a UK-IRELAND-FRANCE map using SDF 3.0 data. I am getting this data
initially
from an SHP file and then converting them using FME to SDF. As a basis of my
sample
I use the phpsample that is available from the website. So, I create the XML
files and then
together with the SDFs I create the MGP file. I load that package to the
server and then I try
to view the page, but no map is displayed on the screen, nothing. I think
the data are correct
since I can view them clearly using the FME viewer as SDF 3. It might have
to do with some sort
of scaling that i have to apply like in the parameters <Extends> and
<Bounds> in some of the XML files.
I have attached my package as zip file, please if somebody could try it to
see if it works I would highly
appreciate it. Also if someone knows how to create a simple demo in PHP and
few dummy data please
email me your demo. Thank you in advance.
Dimitrios
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060504/c54e0b9f/attachment.html
More information about the Mapguide-users mailing list
