[mapguide-users] Installing mapguide
Javier de la Torre jatorre at gmail.com
Thu May 4 12:23:12 EDT 2006
Yes, I was logged as root.
The file /usr/include/jpeglib.h does not exist.
I downloaded the jpeg-6b and installed it but does not seems to
include this file. It copies others to usr/local/bin.
Thanks.
On 5/4/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
> Were you logged in as root when you did make install? Do you have jpeg
> installed (i.e. does /usr/include/jpeglib.h exist)?
> Traian
> -----Original Message-----
> From: Javier de la Torre [mailto:jatorre at gmail.com]
> Sent: Thursday, May 04, 2006 12:09 PM
> To: users at mapguide.osgeo.org
> Subject: [mapguide-users] Installing mapguide
> Hi,
> I am installing mapguide right now, but I am having some problems
> following the instructions on the PDF file.
> I am trying to use all the default settings on an Intel with Red Hat 9.
> First I installed Apache, Tomcat and PHP (APT) using the provided
> package. Everything seems to be fine, the servers are available and
> everyhting worked fine.
> Then I download the Mapguide server an Mapguider server extensions and
> I build the OEMcomponents. This also seems to compile fine.
> IMake 1.0: Build Successful ........................
> Done building OEM components .......................
> Then I go and try to build and install the default configuration:
> aclocal    I get this:
> acinclude.m4:7: warning: underquoted definition of MAP_HELP_STRING
>   run info '(automake)Extending aclocal'
>   or see
> http://sources.redhat.com/automake/automake.html#Extending-aclocal
> acinclude.m4:12: warning: underquoted definition of MAP_SUBST
> acinclude.m4:19: warning: underquoted definition of MAP_FAST_OUTPUT
> acinclude.m4:25: warning: underquoted definition of MAP_GEN_CONFIG_VARS
> acinclude.m4:67: warning: underquoted definition of
> MAP_GENERATE_MAKEFILES
> acinclude.m4:74: warning: underquoted definition of MAP_OUTPUT
> acinclude.m4:83: warning: underquoted definition of
> MAP_DEFINE_TYPE_RLIM_T
> acinclude.m4:108: warning: underquoted definition of
> MAP_SUBST_EXPANDED_ARG
> acinclude.m4:115: warning: underquoted definition of
> MAP_EXPORT_ARGUMENTS
> libtoolize --force OK
> automake --add-missing --copy   OK
> autoconf    OK
> ./configure   OK
> make OK
> make check OK
> make install  get into troubles... After lot of messages I start
> getting errors, this is the first one:
> BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or directory
> BOpcodeHandler.cpp:4970: error: field `jerr' has incomplete type
> And I can not continue following the instructions :(
> Anybody can help?
> Thanks in advance.
> Javier.
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
