[mapguide-users] Installing mapguide
Javier de la Torre jatorre at gmail.com
Thu May 4 12:57:50 EDT 2006
Ups...
Now it fails somehwere else. Now I get this at the end of "make"
make[2]: *** [ServiceControllerBuild.lo] Error 1
make[2]: Leaving directory
`/root/mapguide_install/mapguide-1.0.0/Common/Service'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Common'
make: *** [all-recursive] Error 1
Any idea of what can this be?
Thanks.
On 5/4/06, Javier de la Torre <jatorre at gmail.com> wrote:
> Thanks all,
> I finally did a yum install libjpeg-devel and this installed the
> requiered libraries.
> Seems that I passed this step now :)
> It could be interesting to include in the documentation that the
> package that is needed is libjpeg-devel. Most people can then do a
> up2date or yum or apt-get to install it easily.
> Thanks again.
> Javier.
> On 5/4/06, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> > You might have to specify --enable-shared as an input to the configure
> > script.
> > Jason
> > -----Original Message-----
> > From: Javier de la Torre [mailto:jatorre at gmail.com]
> > Sent: Thursday, May 04, 2006 09:36
> > To: users at mapguide.osgeo.org
> > Subject: Re: [mapguide-users] Installing mapguide
> > no, there is nothing there...
> > Am I installing the correct library? In the documentation it says:
> > The libjpeg.so library is required. It is installed by default with most
> > Linux distributions. If you do not have it, you can download the source
> > from the Independent JPEG Group: www.ijg.org.
> > I downloaded from there:
> > http://www.ijg.org/files/jpegsrc.v6b.tar.gz
> > Now I am not sure...
> > JAvier.
> > On 5/4/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
> > > Did it put it under /usr/local/include by any chance?
> > > Sent: Thursday, May 04, 2006 12:23 PM
> > > Yes, I was logged as root.
> > > The file /usr/include/jpeglib.h does not exist.
> > > I downloaded the jpeg-6b and installed it but does not seems to
> > > include this file. It copies others to usr/local/bin.
> > > Thanks.
> > > > Were you logged in as root when you did make install? Do you have
> > > > jpeg installed (i.e. does /usr/include/jpeglib.h exist)?
> > > > Traian
> > > > Sent: Thursday, May 04, 2006 12:09 PM
> > > > Subject: [mapguide-users] Installing mapguide
> > > > Hi,
> > > > I am installing mapguide right now, but I am having some problems
> > > > following the instructions on the PDF file.
> > > > I am trying to use all the default settings on an Intel with Red Hat
> > > 9.
> > > > First I installed Apache, Tomcat and PHP (APT) using the provided
> > > > package. Everything seems to be fine, the servers are available and
> > > > everyhting worked fine.
> > > > Then I download the Mapguide server an Mapguider server extensions
> > > > and I build the OEMcomponents. This also seems to compile fine.
> > > > IMake 1.0: Build Successful ........................
> > > > Done building OEM components .......................
> > > > Then I go and try to build and install the default configuration:
> > > > aclocal    I get this:
> > > > acinclude.m4:7: warning: underquoted definition of MAP_HELP_STRING
> > > >   run info '(automake)Extending aclocal'
> > > >   or see
> > > > http://sources.redhat.com/automake/automake.html#Extending-aclocal
> > > > acinclude.m4:12: warning: underquoted definition of MAP_SUBST
> > > > acinclude.m4:19: warning: underquoted definition of MAP_FAST_OUTPUT
> > > > acinclude.m4:25: warning: underquoted definition of
> > > MAP_GEN_CONFIG_VARS
> > > > acinclude.m4:67: warning: underquoted definition of
> > > > MAP_GENERATE_MAKEFILES
> > > > acinclude.m4:74: warning: underquoted definition of MAP_OUTPUT
> > > > acinclude.m4:83: warning: underquoted definition of
> > > > MAP_DEFINE_TYPE_RLIM_T
> > > > acinclude.m4:108: warning: underquoted definition of
> > > > MAP_SUBST_EXPANDED_ARG
> > > > acinclude.m4:115: warning: underquoted definition of
> > > > MAP_EXPORT_ARGUMENTS
> > > > libtoolize --force OK
> > > > automake --add-missing --copy   OK
> > > > autoconf    OK
> > > > ./configure   OK
> > > > make OK
> > > > make check OK
> > > > make install  get into troubles... After lot of messages I start
> > > > getting errors, this is the first one:
> > > > BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or directory
> > > > BOpcodeHandler.cpp:4970: error: field `jerr' has incomplete type
> > > > And I can not continue following the instructions :(
> > > > Anybody can help?
> > > > Thanks in advance.
> > > > Javier.
> > > > - To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > > > For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
