[mapguide-users] Installing mapguide
Javier de la Torre jatorre at gmail.com
Thu May 4 14:30:23 EDT 2006
By the way...
I looked around and did not find a PostGIS FDO Provider.. what a
pitty! Is there any plan of creating one? Is there anybody working on
this?
Thanks.
Javier.
On 5/4/06, Javier de la Torre <jatorre at gmail.com> wrote:
> I am loading lot of data in a PostGIS database so I am bored :)
> I tried modifying this as you said and now I got a different error...
> I could try to upgrade to gcc 4 but this is hard, this is a
> dependencies nightmare...
> For your info this is the error I get now:
> de-1.0.0/Server/src/UnitTesting/.libs
> /usr/bin/ld: cannot find -lACE
> collect2: ld returned 1 exit status
> make[3]: *** [mgserver] Error 1
> make[3]: Leaving directory
> `/root/mapguide_install/mapguide-1.0.0/Server/src/Core'
> make[2]: *** [all-recursive] Error 1
> make[2]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Server/src'
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/root/mapguide_install/mapguide-1.0.0/Server'
> make: *** [all-recursive] Error 1
> On 5/4/06, Traian Stanev <traian.stanev at autodesk.com> wrote:
> > OK. This more or less matches what I was seeing -- I was trying to
> > compile on gentoo with gcc 3.4 yesterday. It has to do with some
> > templates in the ACE component. If I fix it I will send you the patch
> > needed to the ACE global header.
> > If you are feeling bored until then, you could try opening
> > ./Oem/ACE/ACE_wrappers/ace/Global_Macros.h and replace the two
> > occurences of (__GNUC__ >= 4) by (__GNUC__ >= 3). However, I am not sure
> > this is sufficient, since I haven't gotten through the whole ACE build
> > successfully yet.
> > Or you could try a different version of gcc but that's probably more
> > painful if you don't have one installed already.
> > Traian
> > -----Original Message-----
> > From: Javier de la Torre [mailto:jatorre at gmail.com]
> > Sent: Thursday, May 04, 2006 1:35 PM
> > To: users at mapguide.osgeo.org
> > Subject: Re: [mapguide-users] Installing mapguide
> > gcc (GCC) 3.4.4 20050721 (Red Hat 3.4.4-2)
> > > I think I have seen this problem before. What version of gcc are you
> > > using?
> > > Sent: Thursday, May 04, 2006 1:03 PM
> > > Ok... I hope this is enough:
> > > make[2]: Entering directory
> > > `/root/mapguide_install/mapguide-1.0.0/Common/Service'
> > > if /bin/sh ../../libtool --mode=compile --tag=CXX g++
> > > -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
> > > -DPACKAGE_VERSION=\"1.0.0\" -DPACKAGE_STRING=\"mapguide\ 1.0.0\"
> > > -DPACKAGE_BUGREPORT=\"http://www.mapguide.osgeo.org\"
> > > -DPACKAGE=\"mapguide\" -DVERSION=\"1.0.0\" -DSTDC_HEADERS=1
> > > -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
> > > -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
> > > -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1
> > > -DHAVE_DLFCN_H=1 -DSTDC_HEADERS=1 -DHAVE_UNISTD_H=1 -DHAVE_MATH_H=1
> > > -DHAVE_NETDB_H=1 -DHAVE_NETINET_IN_H=1 -DHAVE_SYS_TYPES_H=1
> > > -DHAVE_SYS_SOCKET_H=1 -DHAVE_GETHOSTBYNAME=1 -DHAVE_SOCKET=1
> > > -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1  -I. -I.
> > > -IController -ICoordinateSystem -IData -IException -IGeometry
> > > -IMapLayer -INet -IServices -ISystem -IUtil -I../Security
> > > -I../MdfParser -I../MdfModel -I../../Oem/ACE/ACE_wrappers
> > > -I../../Oem/geos-2.2.0/source/headers
> > > -I../../Oem/dbxml-2.2.13/xerces-c-src/src -I../../Oem/proj-4.4.9/src
> > > -I../../Oem/gdal-1.3.0/ogr -I../../Oem/gdal-1.3.0/port
> > > -I../../Common/CoordinateSystem    -g -D_DEBUG -MT
> > > ServiceControllerBuild.lo -MD -MP -MF
> > > ".deps/ServiceControllerBuild.Tpo" -c -o ServiceControllerBuild.lo
> > > `test -f 'Controller/ServiceControllerBuild.cpp' || echo
> > > './'`Controller/ServiceControllerBuild.cpp; \
> > > then mv -f ".deps/ServiceControllerBuild.Tpo"
> > > ".deps/ServiceControllerBuild.Plo"; else rm -f
> > > ".deps/ServiceControllerBuild.Tpo"; exit 1; fi
> > >  g++ -DPACKAGE_NAME=\"mapguide\" -DPACKAGE_TARNAME=\"mapguide\"
> > > -DPACKAGE_VERSION=\"1.0.0\" "-DPACKAGE_STRING=\"mapguide 1.0.0\""
> > > -DHAVE_HTONS=1 -DHAVE_CONNECT=1 -DHAVE_SHUTDOWN=1 -I. -I. -IController
> > > -ICoordinateSystem -IData -IException -IGeometry -IMapLayer -INet
> > > -IServices -ISystem -IUtil -I../Security -I../MdfParser -I../MdfModel
> > > -I../../Oem/ACE/ACE_wrappers -I../../Oem/geos-2.2.0/source/headers
> > > ServiceControllerBuild.lo -MD -MP -MF .deps/ServiceControllerBuild.Tpo
> > > -c Controller/ServiceControllerBuild.cpp  -fPIC -DPIC -o
> > > .libs/ServiceControllerBuild.o
> > > In file included from
> > > ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.h:940,
> > >                  from
> > ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:18,
> > >                  from ../../Oem/ACE/ACE_wrappers/ace/Acceptor.h:24,
> > >                  from ./AceCommon.h:56,
> > >                  from Controller/Controller.cpp:18,
> > >                  from Controller/ServiceControllerBuild.cpp:18:
> > > ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp: In member
> > > function `int ACE_Hash_Map_Manager_Ex<EXT_ID, INT_ID, HASH_KEY,
> > > COMPARE_KEYS, ACE_LOCK>::close_i()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:158: error:
> > > expected class-name before '(' token
> > > COMPARE_KEYS, ACE_LOCK>::unbind_all_i()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:190: error:
> > > COMPARE_KEYS, ACE_LOCK>::unbind_i(ACE_Hash_Map_Entry<EXT_ID,
> > > INT_ID>*)':
> > > ../../Oem/ACE/ACE_wrappers/ace/Hash_Map_Manager_T.cpp:289: error:
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.h:286,
> > >                  from
> > > ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:26,
> > >                  from
> > ../../Oem/ACE/ACE_wrappers/ace/Strategies_T.h:25,
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In member function
> > > `void ACE_Unbounded_Queue<T>::delete_nodes()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:133: error:
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp: In destructor
> > > `ACE_Unbounded_Queue<T>::~ACE_Unbounded_Queue()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:153: error:
> > > `int ACE_Unbounded_Queue<T>::dequeue_head(T&)':
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Queue.cpp:223: error:
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.h:307,
> > >                  from
> > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:34,
> > >                  from ../../Oem/ACE/ACE_wrappers/ace/Containers.h:69,
> > >                  from
> > > ../../Oem/ACE/ACE_wrappers/ace/Thread_Manager.h:27,
> > >                  from
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In member function
> > > `void ACE_Unbounded_Set<T>::delete_nodes()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:107: error: expected
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp: In destructor
> > > `ACE_Unbounded_Set<T>::~ACE_Unbounded_Set()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:126: error: expected
> > > `int ACE_Unbounded_Set<T>::remove(const T&)':
> > > ../../Oem/ACE/ACE_wrappers/ace/Unbounded_Set.cpp:230: error: expected
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.h:1986,
> > >                  from
> > >                  from
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In member function
> > > `void ACE_Unbounded_Stack<T>::delete_all_nodes()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:171: error: expected
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp: In destructor
> > > `ACE_Unbounded_Stack<T>::~ACE_Unbounded_Stack()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:239: error: expected
> > > `int ACE_Unbounded_Stack<T>::pop(T&)':
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:275: error: expected
> > > `int ACE_Unbounded_Stack<T>::remove(const T&)':
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:334: error: expected
> > > `int ACE_Ordered_MultiSet<T>::remove(const T&)':
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1582: error: expected
> > > `void ACE_Ordered_MultiSet<T>::delete_nodes()':
> > > ../../Oem/ACE/ACE_wrappers/ace/Containers_T.cpp:1786: error: expected
> > > make[2]: *** [ServiceControllerBuild.lo] Error 1
> > > make[1]: *** [check-recursive] Error 1
> > > `/root/mapguide_install/mapguide-1.0.0/Common'
> > > make: *** [check-recursive] Error 1
> > > On 5/4/06, Walt Welton-Lair <walt.welton-lair at autodesk.com> wrote:
> > > > You need to show us more of the error trace...
> > > > Sent: Thursday, May 04, 2006 12:58 PM
> > > > Ups...
> > > > Now it fails somehwere else. Now I get this at the end of "make"
> > > > Any idea of what can this be?
> > > > Thanks.
> > > > > Thanks all,
> > > > > I finally did a yum install libjpeg-devel and this installed the
> > > > > requiered libraries.
> > > > > Seems that I passed this step now :)
> > > > > It could be interesting to include in the documentation that the
> > > > > package that is needed is libjpeg-devel. Most people can then do a
> > > > > up2date or yum or apt-get to install it easily.
> > > > > Thanks again.
> > > > > Javier.
> > > > > On 5/4/06, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> > > > > > You might have to specify --enable-shared as an input to the
> > > > configure
> > > > > > script.
> > > > > > Jason
> > > > > > Sent: Thursday, May 04, 2006 09:36
> > > > > > no, there is nothing there...
> > > > > > Am I installing the correct library? In the documentation it
> > says:
> > > > > > The libjpeg.so library is required. It is installed by default
> > > with
> > > > most
> > > > > > Linux distributions. If you do not have it, you can download the
> > > > source
> > > > > > from the Independent JPEG Group: www.ijg.org.
> > > > > > I downloaded from there:
> > > > > > http://www.ijg.org/files/jpegsrc.v6b.tar.gz
> > > > > > Now I am not sure...
> > > > > > JAvier.
> > > > > > > Did it put it under /usr/local/include by any chance?
> > > > > > > Sent: Thursday, May 04, 2006 12:23 PM
> > > > > > > Yes, I was logged as root.
> > > > > > > The file /usr/include/jpeglib.h does not exist.
> > > > > > > I downloaded the jpeg-6b and installed it but does not seems
> > to
> > > > > > > include this file. It copies others to usr/local/bin.
> > > > > > > Thanks.
> > > > > > > > Were you logged in as root when you did make install? Do you
> > > > have
> > > > > > > > jpeg installed (i.e. does /usr/include/jpeglib.h exist)?
> > > > > > > > Traian
> > > > > > > > Sent: Thursday, May 04, 2006 12:09 PM
> > > > > > > > Subject: [mapguide-users] Installing mapguide
> > > > > > > > Hi,
> > > > > > > > I am installing mapguide right now, but I am having some
> > > > problems
> > > > > > > > following the instructions on the PDF file.
> > > > > > > > I am trying to use all the default settings on an Intel with
> > > Red
> > > > Hat
> > > > > > > 9.
> > > > > > > > First I installed Apache, Tomcat and PHP (APT) using the
> > > > provided
> > > > > > > > package. Everything seems to be fine, the servers are
> > > available
> > > > and
> > > > > > > > everyhting worked fine.
> > > > > > > > Then I download the Mapguide server an Mapguider server
> > > > extensions
> > > > > > > > and I build the OEMcomponents. This also seems to compile
> > > fine.
> > > > > > > > IMake 1.0: Build Successful ........................
> > > > > > > > Done building OEM components .......................
> > > > > > > > Then I go and try to build and install the default
> > > > configuration:
> > > > > > > > aclocal    I get this:
> > > > > > > > acinclude.m4:7: warning: underquoted definition of
> > > > MAP_HELP_STRING
> > > > > > > >   run info '(automake)Extending aclocal'
> > > > > > > >   or see
> > > > http://sources.redhat.com/automake/automake.html#Extending-aclocal
> > > > > > > > acinclude.m4:12: warning: underquoted definition of
> > MAP_SUBST
> > > > > > > > acinclude.m4:19: warning: underquoted definition of
> > > > MAP_FAST_OUTPUT
> > > > > > > > acinclude.m4:25: warning: underquoted definition of
> > > > > > > MAP_GEN_CONFIG_VARS
> > > > > > > > acinclude.m4:67: warning: underquoted definition of
> > > > > > > > MAP_GENERATE_MAKEFILES
> > > > > > > > acinclude.m4:74: warning: underquoted definition of
> > MAP_OUTPUT
> > > > > > > > acinclude.m4:83: warning: underquoted definition of
> > > > > > > > MAP_DEFINE_TYPE_RLIM_T
> > > > > > > > acinclude.m4:108: warning: underquoted definition of
> > > > > > > > MAP_SUBST_EXPANDED_ARG
> > > > > > > > acinclude.m4:115: warning: underquoted definition of
> > > > > > > > MAP_EXPORT_ARGUMENTS
> > > > > > > > libtoolize --force OK
> > > > > > > > automake --add-missing --copy   OK
> > > > > > > > autoconf    OK
> > > > > > > > ./configure   OK
> > > > > > > > make OK
> > > > > > > > make check OK
> > > > > > > > make install  get into troubles... After lot of messages I
> > > start
> > > > > > > > getting errors, this is the first one:
> > > > > > > > BOpcodeHandler.cpp:52:29: jpeglib.h: No such file or
> > directory
> > > > > > > > BOpcodeHandler.cpp:4970: error: field `jerr' has incomplete
> > > type
> > > > > > > > And I can not continue following the instructions :(
> > > > > > > > Anybody can help?
> > > > > > > > Thanks in advance.
> > > > > > > > Javier.
> > > > > > > > - To unsubscribe, e-mail:
> > users-unsubscribe at mapguide.osgeo.org
> > > > > > > > For additional commands, e-mail:
> > users-help at mapguide.osgeo.org
> > > > > > > To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> > > > > > > For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users mailing list
