I've set-up wms on MapGuide, but when I try to access the MG layers from another computer (using ArcMap), no layers are available. The connection is there, but the data cannot be found. Is anyone else successfully using wms to access their data from an outside source? The path I use is <http://204.244.79.27//mapguide/mapagent/mapagent.fcgi>, should there be more? Joy.
