[mapguide-users] OnSelection Event?
Willem Schwarte willem at giskit.nl
Fri May 5 03:21:37 EDT 2006
Ok, I came across a short sample in one of the documentations and
created this very simple page:
// testing the getXMLSelection...
// testframe
// ViewerFrame (map contents)
<html>
<head>
</head>
<script>
function doXml()
            xmlSel = parent.ViewerFrame.mapFrame.GetSelectionXML();
            params = new Array("test","1", "SEL", xmlSel);
parent.ViewerFrame.formFrame.Submit("http://localhost/sites/viewer/mytes
t.php", params, "taskPaneFrame");
</script>
<body>
if($_POST['test']==1)
            echo $_POST['SEL'];
}else
<a href="#" onClick="doXml();">Show it!</a>
</body>
</html>
First I will select an object on the map, next I will click the  'Show
it!' link...
In the taskpaneframe the mytest.php file is loaded. If I look at the
source there is a piece of XML:
<FeatureSet>
<Layer id="8fa14c82-ffff-ffff-8000-0014a40277a1">
<Class id="Default:lki_v">
<ID>rBAAAA==</ID>
</Class>
</Layer>
</FeatureSet>
How can I use this to get the properties from this object on the map?
Is still need this mytest page to be executed automatically on selection
of the object..
Thanks
Van: Willem Schwarte [mailto:willem at giskit.nl]
Verzonden: vrijdag 5 mei 2006 7:33
Aan: users at mapguide.osgeo.org
Onderwerp: [mapguide-users] OnSelection Event?
I've just read the dev manual and want to try to create a little test
program, to get me started on understanding the flow of events etc..
What I want is:
When something gets selected, read a property and call an asp-page in
another frame (in short).
But how can I tell if something is selected?
I suppose there is no onSelectionChanged event like in MG6.5. So this
would be done on a onClick? Where would I put the code for this?
Willem
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060505/785b3f50/attachment.html
More information about the Mapguide-users mailing list
