[mapguide-users] Projections
Kori Maleski
km at pat.ca
Fri May 12 16:43:14 EDT 2006
Hi Joy,
The map should always be in the same projection as the Raster imagery.
The Vector can be in any projection you specify - it will be reprojected on the fly for the map.
Why the imagery and vector arent showing in the same map at the same time means something is obviously amiss.
Not to be redundant - does everything overlay properly in your desktop GIS software?
Kori Maleski BSc.
Senior Technical Consultant
Pacific Alliance Technologies
Suite 400 - 534 17 Ave. SW Calgary, AB CANADA T2S 0B1
TEL 403.770.1917 FAX 877.691.9149 TOL 877.691.9171 www.pat.ca <http://www.pat.ca/>
Sent: Fri 12/05/2006 1:00 PM
Subject: [mapguide-users] Projections
I am having problems viewing a map with both raster and vector data.
The vector data is in UTM 10 - AND 83 coordinate projection, the raster
data is in and Albers projection. I've tried creating the map in both
the different coordinate systems... either one or the other shows-up,
never both. Does anyone have an idea as to where I am going wrong, do
I need to define something I haven't?
Thanks Again,
Joy Appler.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
Name: not available
Type: application/ms-tnef
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060512/95cff987/attachment.bin
More information about the Mapguide-users
