AW: [mapguide-users] How to load raster?
Thomas Grosser
grosser at kom21.de
Tue May 16 15:30:55 EDT 2006
Dear Joseph,
Thanks for the answer, the link and the data. But I didn´t suceed ! I try to load them alone, with a raster catalog and with correcting the band to "1" - nothing to see !
Can you help me how you solve it in your project ???
Thanks a lot ...
Thomas Grosser
- Geschäftsleitung -
Kom21 - Nürnberg
Großweidenmühlstraße 28
90419 Nürnberg
Tel.: 0911 - 378 33 85
Fax: 0911 - 378 33 86
Web: www.kom21.de
-----Ursprüngliche Nachricht-----
Von: Joseph Doherty [mailto:jdoherty at Microdesk.com]
Gesendet: Dienstag, 16. Mai 2006 20:53
An: users at mapguide.osgeo.org
Betreff: RE: [mapguide-users] How to load raster?
Hi Thomas,
I suspect you used tif images. If this is the case, you would not see the panel as I describe. To test this out try downloading and extracting these jpgs and world files http://www.visittownsquare.com/MG/sheboygan_jpgs.zip , using the sheboygan sample, drag and drop all the jpgs to the Sheboygan folder, for coordinate system, choose LL84, and pick up the directions from there.
Let me know how this works.
Mahalo,
Joseph Doherty
Software Engineer
Oracle Certified Professional
Microdesk, Inc.
E: jdoherty at microdesk.com
P: 781-419-8105
C: 781-820-1389
F: 781-890-5275
www.microdesk.com
-----Original Message-----
Sent: Tuesday, May 16, 2006 10:24 AM
Subject: AW: [mapguide-users] How to load raster?
Dear Joseph,
We also try to follow your steps - but we didn´t find the section with the "configuration file" ...
Can anyone help us ? Because when we load raster everything seems to be allright, but we don´t see any image !!!
Mit freundlichen Grüßen
Thomas Grosser
Kom21 - Nürnberg
90419 Nürnberg
Web: www.kom21.de
Gesendet: Freitag, 12. Mai 2006 15:37
I have seen parts of your question in a few threads so I will attempt to
consolidate from those sources.
1) Download the Raster Provider
(https://mapguide.osgeo.org/servlets/ProjectDocumentList?folderID=35&exp
andFolder=35&folderID=35)
Follow the readme.txt instruction for installation, keep in mind that if
you have Studio and MapGuide Open Source Server installed on the same
box, there is an FDO folder under both product directories. My
suggestion, configure them both the same.
2) Now work up a couple jpegs or tiffs and related world files
3) Get the data into Studio and run the fix, so do the following:
- In Studio, drag and drop selected images onto the "Data"
folder in the tree
- Set Coordinates, file locations, name etc ... and Run the
Load Procedure
- Then open the new "data" item that was created
- At this point open a Notepad window and then back to Studio
- In the "Configuration File:" section, click "Edit"
- In the window that opens, select, cut and paste contents into
the Notepad window
- In Notepad, search for all locations of "Band", it should
look like <Band name="RGB" number="1">
- If the "number=" is something other than "1" then set it to
"1"
- Select the contents of the Notepad and paste back into the
window in Studio
- Click "Ok" and then "Test .."
- A prompt to save the resource should appear, click "Yes"
- Did the Test pass?
Let us know how it goes.
Mahalo,
Joseph Doherty
Software Engineer
Microdesk, Inc.
P: 781-419-8105
C: 781-820-1389
F: 781-890-5275
www.microdesk.com
Sent: Friday, May 12, 2006 9:01 AM
Subject: [mapguide-users] How to load raster?
hi everybody!
i tried lots of ways to load raster image but i can't do it. Somebody
tell
me any way to load raster?
-Which components are required?
-What's the process order?
-Which image format is best stable?
I have last versions of studio and mapguideOS but not solves the
problems.
This is very important for me and my carrier please help guys....
Thanx!
View this message in context:
http://www.nabble.com/How-to-load-raster--t1607349.html#a4357653
Sent from the OSGeo MapGuide forum at Nabble.com.
To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
For additional commands, e-mail: users-help at mapguide.osgeo.org
More information about the Mapguide-users
