Running MapGuide on a non-networked PC
Chris White
chris.white at keytraffic.com
Thu May 18 10:19:08 EDT 2006
I have a problem trying to run Mapguide on a non-networked machine (i.e.
network cable unplugged). This is needed to allow demonstrations away
from the office however when I do this I get the following error in the
browser:
Type 'OSGeo.MapGuide.MgConnectionFailedException' in Assembly
'MapGuideDotNetApi, Version=1.0.0.16407, Culture=neutral,
PublicKeyToken=null' is not marked as serializable.
This is easily replicated by removing the network cable. I'm running on
Windows Server 2003 R2 on IIS. Has anyone else seen / solved this?
Thanks in advance
Chris White
Software Architect
Key Traffic Systems Ltd.
Ardencroft Court
Ardens Grafton
Alcester
Warwickshire
B49 6DP
Main: +44(0)8451 303040
Fax: +44(0)8451 303141
Mailto: chris.white at keytraffic.com
<mailto:%20chris.white at keytraffic.com>
Web: www.keytraffic.com <http://www.keytraffic.com/>
This e-mail & any attachments are intended only for the use of the
person(s) to whom it is addressed. It may contain information that is
privileged and confidential within the meaning of applicable law. If you
are not the intended recipient, please contact the sender as soon as
possible by return mail or Tel +44 (0) 8451 303040. The views expressed
in this communication may not necessarily be the views held by Key
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060518/3db50f85/attachment.html
More information about the Mapguide-users
