Installation on Windows Server 2003 (64-bit) - one hint !
Thomas Grosser grosser at kom21.de
Sat May 20 08:18:41 EDT 2006
I solved my CGI / PHP problem (from my sight today ;-)) very easy !
After installing server and webextensions by hand along the installation guide there was everything installed in the directory C:\Program Files (x86)\MapGuideOpenSource\... , also the directory for the C:\Program Files (x86)\MapGuideOpenSource\WebServerExtensions\Php\
In this directory there is the PHP.INI, and within this file there is one line with the (hard coded ?) path C:\Program Files\MapGuideOpenSource\... !
I found this after copying in my desperation all from C:\Program Files (x86)\MapGuideOpenSource\ to C:\Program Files\MapGuideOpenSource\ and it suddenly runs !
Then I began the search and found the reason above. So, modifying the PHP.INI in C:\Program Files (x86)\MapGuideOpenSource\WebServerExtensions\Php\ helps a lot ...
Mit freundlichen Grüßen
Thomas Grosser
- Geschäftsleitung -
Kom21 - Nürnberg
Großweidenmühlstraße 28
90419 Nürnberg
Tel.: 0911 - 378 33 85
Fax: 0911 - 378 33 86
Web: www.kom21.de
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20060520/a41048c6/attachment.html
More information about the Mapguide-users mailing list
